Sponsored by: Real Truck
Front diff cover 2002 F-350
Old Feb 6, 2015 | 11:45 PM
351WTF's Avatar
351WTF
Question Front diff cover 2002 F-350
I was just curious if anyone on here had already changed one of these out. I know they are somewhat prone to rotting out from time to time and my question is; Can i change this out without having to remove any of the steering linkage? Will the old cover just slip off free and clear or do i have to disconnect some tie rods to get it past the ring gear?
Thanks in advance.
Old Feb 7, 2015 | 06:33 PM
mattymax's Avatar
mattymax
I have an 08 and the cover slipped off with no issues. I changed out the fluid a few weeks back
Matt
Old Feb 8, 2015 | 12:06 AM
351WTF's Avatar
351WTF
Lightbulb
Thank you sir!
Old Feb 8, 2015 | 05:21 PM
Diamnd1's Avatar
Diamnd1
Just did my '04 last week. Only issue I had was the allen bolt. Hard to get to with what I had. Other than that, no issues.
Old Feb 9, 2015 | 08:18 PM
El Campo's Avatar
El Campo
Even if you do have to take a tie rod loose it is only the Driver's side one which is easy. I put a jack under the rod (not on stud) and after taking the nut off just put a slight amount of pressure on jack and then tap sharply on the knuckle (where stud goes through) and it pops loose easily. Makes it easier to get cover on straight without smearing gasket maker around.
jg96powerstroker
Jan 28, 2016 06:25 PM
stickittoem
General Diesel Discussion
Mar 7, 2008 09:46 PM
ckal704
Jul 9, 2007 07:17 AM
Reidicus
Oct 19, 2006 08:12 AM
Mopey
Apr 23, 2005 06:45 AM
