Front hub question
Old Feb 15, 2015 | 09:01 AM
harley4jcs's Avatar
harley4jcs
Originally Posted by brooksa44
I replaced drivers side wheel hub as it was shot out, took my time and the replacement went without a hitch except after test drive I am still getting a squeak from that wheel when going around corner to the right.
Any suggestions as what might be causing this? Not the dust shield and no noise when free spinning on a jack, so I'm at a loss!
Some members have been reporting singing ball joints ! ?
Old Feb 15, 2015 | 09:05 AM
brooksa44's Avatar
brooksa44
Hmmm ball joints seemed to be Aok, I guess I will take closer look, thanks
Old Feb 15, 2015 | 01:20 PM
Lance Helmert's Avatar
Lance Helmert
Just a note on all sealed bearings. They usually just have a seal on each side that can be popped out with a 45 degree pick. My cousin showed me some new ones and they have very little grease in them. I pop out the seal, add grease, and then push the seal back on. Usually even one that's pressed in to an idler pulley, you have access to one side and can add grease. I use the grease in my grease gun, but I use a synthetic grease.
Old Feb 15, 2015 | 02:45 PM
howler4x4's Avatar
howler4x4
Check the axle U-Joint. Even if not rotating they still have to articulate when you turn.
If they seem tight then oil them. ATF is good for that. Worked for me.
Old Feb 15, 2015 | 04:37 PM
brooksa44's Avatar
brooksa44
I greased the new seal, made sure everything was clean before installing new hub unit.
I just got back from a round trip of about 75 miles and everything seems to good to go but slow right turns will produce a squeak still, driving me freaking nuts!
I will double check u-joints but they seem to be holding, I didn't see a zerk anywhere on them , did I miss them?
prorad
Oct 7, 2014 03:03 PM
03F350XLT
Feb 25, 2011 08:59 PM
SpringerPop
Aug 9, 2007 07:18 PM
drillerdan
Nov 21, 2004 06:28 PM
norcalcapri
Jan 11, 2004 02:11 AM
