swapped it out with another one and my problem went away forever. it was an intermittent low power issue, though and it definitely felt like the truck was just governed back. it idled fine, and made power fine most of the time, but when the problem occured, i could barely make it up a decent size hill in 2nd gear.
seems like such a problem with the baro is quite rare, but was definitely the culprit in my case.
I had a low power problem and it was my ICP sensor. I had no symptoms of the sensor going out other than a low power issue, until I went out and started the truck one day and it was idling terribly and the CEL came on.
