help with installing a nav system
Old Feb 7, 2015 | 01:22 PM
Marco Elam's Avatar
Marco Elam
Have a 2004 ford 350 6.0 larait 4xX
Im installing a nav and a back up camera to the truck
I wondered if anyone nee or had a wire chart i could use.
Mainly need help with wireing the nav unit to the truck as far as reverse wire. The nav itself has a pink wire for reves but im bot sure where i wire it to in the truck. Thank you.
Old Feb 7, 2015 | 05:54 PM
Maxium4x4's Avatar
Maxium4x4
I am sure a few have done this.... Going from (OEM) single Din, to the Nav unit double Din. Items needed will be a pigtail to fit your model truck and a filler plate. You should be able to pick up most items on Ebay. What radio is going in?
Old Feb 7, 2015 | 06:22 PM
Georgia8er's Avatar
Georgia8er
Have you already bought everything? I know some will chime in "you can do it yourself cheaper!" and stuff like that, but Crutchfield: Car Stereo, Speakers, Home Theater, Pro Audio, 4k TV has great service and if you buy a head unit (NAV/Radio/Etc) it will come with everything you need to install it plus instructions. If you get stuck, they have great over the phone customer service.
One thing I would recommend is trying a wireless system for your backup camera. It will make installation easier and you can always run a separate line from the rear if it doesn't have acceptable performance.
Old Feb 8, 2015 | 03:08 PM
Marco Elam's Avatar
Marco Elam
Maxium4x4, i have everything ready , i just need to know whete to wire it up so the camera kicks on in reverse.
Old Feb 8, 2015 | 03:36 PM
RideDiesel88's Avatar
RideDiesel88
Reverse light circuit, right? When the reverse lights light up when the circuit is complete it should turn on camera at same time. Try looking up the wiring diagram for the new models that come out the factory with them
Old Feb 8, 2015 | 05:27 PM
87crewdually's Avatar
87crewdually
I hooked the reverse camera activation wire to #2 upfitter switch so I can check the load while driving or see the idiot that gets to close at a traffic light.
Old Feb 8, 2015 | 07:17 PM
Rusty Axlerod's Avatar
Rusty Axlerod
That would be a cool mod, power up the camera AND back feed the reverse lights
Old Feb 8, 2015 | 11:27 PM
87crewdually
In my case I did not tap into the reverse lights at all. No need for me, the switch works perfect.
Old Feb 9, 2015 | 04:32 AM
Rusty Axlerod
My apologies to the OP, we weren't very helpful.
Old Feb 9, 2015 | 02:05 PM
87crewdually
Here's what I found: For your reverse signal wire, use the black/pink wire in the harness located under the brake booster.
Here's where I found it (scroll down to one of the responses on the page):
http://www.modifiedlife.com/2005-ford-f350-car-audio-wire-chart/
This is for 05 but it may be the same as an 04.5
Old Feb 9, 2015 | 07:41 PM
Maxium4x4's Avatar
Maxium4x4
Power for my reverse camera came from the tail light harness.
Old Feb 9, 2015 | 07:53 PM
Rusty Axlerod
Many modern head units with a big display include a sense wire to switch the display to the rear camera when the shifter is moved to reverse and then back to the radio or DVD display when you go back to drive. I think that's what he was asking about. It wouldn't be too hard to find poking around with a meter, the OP was probably just looking to save a few minutes and some aggravation.
paker
1997 - 2003 F150
Feb 27, 2019 01:39 PM
Aquik72
16
Jan 6, 2019 03:20 AM
firemanjeff
Oct 31, 2017 01:03 PM
jhva
Nov 25, 2011 11:30 AM
A/Ox4
May 25, 2011 01:07 PM
