Sponsored by: Real Truck
aftermarket camera help
Old Oct 27, 2017 | 08:17 PM
firemanjeff's Avatar
firemanjeff
just installed JVC kw-M-730 BT in my 2014 250 i add Maestro RR to control for steering wheel functions . I bought Metra Back up camera, radio works good but i got no back up camera, the little lines come on the screen. I wired the camera to the powered wire to the back light. black wire is grounded. ran the the rca wire to the camera input on the radio. its plugged in. any ideas?
Old Oct 29, 2017 | 05:23 AM
seville009's Avatar
seville009
Best bet would be to go to the manufacturer’s website and ask them; may save you alot of time and trouble.
If you were replacing an oem camera (which it sounds like you didn’t do), I think the dealer has to program it to recognize it. Since you presumably installed the wiring, camera, and screen, that shouldn’t apply.
Old Oct 31, 2017 | 01:03 PM
jp267's Avatar
jp267
Hmm I have that same head unit and a reverse camera with no issues. Did you splice the purple reverse wire into the correct wire under the dash. If I remember right I spliced the purple wire in reverse light wire behind the relay. Then for power I spliced into the taillight reverse light. One wire is live the other is a ground. Also, check that it's plugged into the right port on the head unit. I accidentally plugged mine into AV in at first then remembered there was a separate cam input. Then it all worked. Oh go into the settings and make sure it's turned on as well.
​​Let us know how you make out. Happy to help you troubleshoot!
Mcheath30
Aug 9, 2018 07:21 PM
ChiefGeek
Aug 11, 2017 10:11 AM
oceantrav
Jan 2, 2017 03:44 PM
rutherk1
Feb 17, 2015 02:29 PM
XolieX
2004 - 2008 F150
Mar 1, 2008 11:09 AM
