6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Back up Lamps are Basically Useless
Old 02-06-2015, 10:53 PM
drasm22's Avatar
drasm22
drasm22 is offline
I've noticed that the reverse lights on my 08 F250 are pretty much useless for lighting up what's behind. I've had my truck for 7 or 8 months and hadn't really paid attention to it until now. Does anyone have a recommendation for a better bulb to replace the stock bulbs? Replacing the entire taillight lens assembly isn't something I'm interested in doing; just hoping a better bulb will do the trick.
Old 02-07-2015, 11:52 AM
CampSpringsJohn's Avatar
CampSpringsJohn
CampSpringsJohn is offline
Old 02-09-2015, 11:16 AM
jmhatchett's Avatar
jmhatchett
jmhatchett is offline
I do a ton of work behind my truck and what not, I installed LED lights on the factory hitch and they run on a switch inside of the truck (aux 4 to be exact so that they can run while in park or truck is off with key in acc position.) but they are super bright and very functional. total cost for the lights was $60 and i installed myself I do all of my own installation it was simple.
Old 02-14-2015, 08:38 PM
drasm22's Avatar
drasm22
drasm22 is offline
Nice! I hadn't thought of adding more lights. Can you post a few pictures to give me an idea what it looks like?
Old 02-16-2015, 10:21 AM
jmhatchett's Avatar
jmhatchett
30" LED light bar custom mounted in grill
LED light pods mounted and wired to Aux 4 for reverse lighting, work lighting, hooking up trailers, etc (also wired on Aux 4 is bed lighting mounted under each bed rail)
Old 02-21-2015, 11:32 AM
drasm22's Avatar
drasm22
drasm22 is offline
Thanks for the pictures! Now I've got to figure out how I want to add auxiliary lighting. Hmmm....
Old 02-21-2015, 12:34 PM
CampSpringsJohn
A friend of mine mounted a couple lights behind the bumper. You can't see them unless you look up behind the bumper. They don't shine very far back, but they provide great light while hooking up his camper or trailer without shining in your face.
slowmans
1999 to 2016 Super Duty
05-13-2009 05:49 PM
EaTmYtAiLpIpEs
10-01-2007 07:26 PM
01redcrew
25
05-18-2007 08:38 PM
01x7.3
01-10-2007 01:09 PM
thenewjohndeere
1978 - 1996 Big Bronco
12-29-2006 10:07 AM
Quick Reply: Back up Lamps are Basically Useless
