back up lights
Old May 9, 2007 | 11:51 PM
01redcrew's Avatar
01redcrew
back up lights
i pulled a buddys boat tongiht after dark and than tried to back it in his garage and couldnt see much at all, i do have tinted windowns but still i think i need some more back up lights but dont want to spend a pretty penny on them and i also want to try and kind of hide them if possible
any ideas thanks
Old May 9, 2007 | 11:56 PM
empiretc's Avatar
empiretc
https://www.ford-trucks.com/forums/5...with-pics.html
I am in the process of doing this
Old May 10, 2007 | 12:22 AM
01redcrew's Avatar
01redcrew
thats good find anythin that i dont let me know
thanks
Old May 10, 2007 | 07:58 PM
mattpowerstroker's Avatar
mattpowerstroker
i installed a set of backup lights that i got from cabelas there a slim light and i mounted them on my hitch and turned them so they were more out to the side intead of straight out i also wired them into the back up lights so i didnt have to worry about putting them on a switch and i would have them as soon as it went into reverse
Old May 10, 2007 | 09:11 PM
01redcrew's Avatar
01redcrew
how was the wiring? Was it easy
Old May 10, 2007 | 11:28 PM
jtharvey's Avatar
jtharvey
Originally Posted by empiretc
That's one nice setup. I like it! I'm curious to see how yours turns out.
Old May 10, 2007 | 11:38 PM
empiretc's Avatar
empiretc
Jeremy, i am still debating if I am going to tie them into the reverse lights or just put them on a manual switch. I'll probably just do the switch (good excuse for upfitters), but I really wish my truck was lifted so I could hide them better.
That is the delay. I want them hidden.
Old May 11, 2007 | 03:27 AM
ryaneverk2's Avatar
ryaneverk2
Mine aren't hidden at all... they're mounted right in the bumper.
I sure like them, though.
http://rides.webshots.com/album/548775191GqIxSI
The other day at a family get-together, I moved my cousin's F150 from in front of the driveway for him, and when I put it in reverse... it was scary. No light back there at all. Felt very vulnerable while backing up. It's strange to drive a vehicle without the extra light back there that I've been used to.
Old May 11, 2007 | 11:10 PM
jtharvey's Avatar
jtharvey
I want them hidden.
Same boat. I personally want mine somewhat hidden. I guess I could start looking for some places under the truck, as it's more of just a thought right now.
Old May 12, 2007 | 09:22 AM
empiretc's Avatar
empiretc
I am looking at some LED tubes. They would mount like reverse sensors. Looks like it would be a hell of a chore to put them in, but no one would guess that they are lights!
Old May 14, 2007 | 11:42 PM
countrycar's Avatar
countrycar
I saw these lights at " stylin concepts." They seem like a pretty good deal and they come with different mounting options too. http://www.stylinconcepts.com/part.a.../categoryid/26Hope this works for yah.. Country
Old May 14, 2007 | 11:53 PM
cangim's Avatar
cangim
When I was looking to hide mine I felt that it dropped the through distance due the the angle, that is why I went with putting them right next to the hitch, hopefully the hitch will offer some protection if I back into an embankment or similar. The center wire in the rv plug is already connected into the reverse circuit and has its own fuse. I would suggest using it and not using the ones in the brake assembly. This way if you add two 55watt lights you're not going to hurt anything at all. I have mine on both a switch and connected to reverse.
Old May 14, 2007 | 11:59 PM
jtharvey's Avatar
jtharvey
Originally Posted by cangim
When I was looking to hide mine I felt that it dropped the through distance due the the angle, that is why I went with putting them right next to the hitch...
Do you have any pictures of your setup? I didn't see any in your gallery.
Old May 15, 2007 | 12:07 AM
cangim's Avatar
cangim
I used to have a few pics of it in the gallery, I will find them and repost
Sweet, found it quick enought to be able to edit here it is: This is an older pic though, I have replace those lights with some new ones but the mounting location is the same.
Old May 15, 2007 | 09:18 AM
Kwikkordead's Avatar
Kwikkordead
Ryan's lights aren't hidden well enough??
IMO that's the best setup that I've seen.
(Nice job there Ryan)
