Remote Transmission Cooler:
Feb 5, 2015 | 01:57 PM
This weekend I'm going to install my Derale remote mount transmission cooler with the fan attached.
Anyone have pics of where they installed theirs?
I'm thinking back behind the cab under the bed inside in the frame somewhere.
Ryan
Feb 5, 2015 | 03:43 PM
Should get plenty of air flow where you are considering. Just don't mount it inline with any U-joints or the Slip Yoke as it would get covered/packed with grease over time.
Feb 5, 2015 | 07:24 PM
Feb 5, 2015 | 09:43 PM
Quote:
Originally Posted by
planehunter
It's all about air flow.
Yep, realize that
With the fan, it doesn't have to be directly in the airstream. Just was interested in seeing where others have placed theirs.
Feb 6, 2015 | 11:51 AM
Can't remember if your bed has the bedside tool box, if not then that is where I'd put it if you're not going to put it up front.
Feb 6, 2015 | 02:27 PM
oddfordjunkie
It does. I was thinking on the other side, but I want to keep it inside the framerails. Less chance for rocks/mud hitting it from the tires.
Feb 6, 2015 | 03:47 PM
Between the Saddle tank on the Drivers side and the Exhaust on the Passenger side it may be a squeeze.
Maybe directly above the axle, your truck is lifted so the rear axle shouldn't be able to up travel high enough to have any concern.
Feb 7, 2015 | 09:19 AM
oddfordjunkie
I'm thinking behind the t-case and in front of the saddle tank may be a good spot.
Denverwells
May 28, 2019 02:06 PM
namnguye
Apr 5, 2018 12:22 PM
Randy777
Apr 23, 2012 05:59 AM
ducktang
Oct 26, 2010 12:56 PM
bronco252
Mar 18, 2010 05:52 AM
