Transmission cooler
Old May 27, 2019 | 07:24 PM
Denverwells's Avatar
Denverwells
Transmission cooler
Do any of you have A/C and an automatic transmission in your 53-56? If so, where did you mount your trans cooler without affecting the efficiency of your a/c evaporator?
Old May 27, 2019 | 11:28 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
Not a 53-56 but, I had the same issue on a non Ford so I mounted a big trans cooler horizontally behind the front bumper. I fabricated a shroud and mounted an electric fan on it. Back when I did it there was no fan cooler combos like today. Cooled very well and I am in AZ.
Old May 28, 2019 | 06:43 AM
jniolon's Avatar
jniolon
old and in the way
here's what I did Denver... I had the same concerns as you and also no room to mount the cooler up front
https://www.fordtruckzone.com/thread...-f-100.664344/
john
Old May 28, 2019 | 10:36 AM
Denverwells
Thx for the info!
Old May 28, 2019 | 11:18 AM
DR Smith's Avatar
DR Smith
I mounted mine under the passenger side frame rail . no fan , c6 trans , never had a problem even in GA HEAT , 351 with air
Old May 28, 2019 | 02:06 PM
Denverwells
Thanks for everyone's input! Got to figure it out, thanks!
bronco252
Mar 18, 2010 05:52 AM
mike L
May 18, 2006 07:34 AM
probablecause
Dec 6, 2005 08:11 AM
rowdy123
Jul 18, 2005 10:24 AM
Platinum01
Dec 31, 2004 06:23 AM
