Fueling issue
Old Feb 6, 2015 | 07:11 AM
  #46
savagebagz's Avatar
savagebagz
Originally Posted by Tugly
Those all look like good number from the text, but I still have this gut feeling you may be defueling at WOT - without evidence to back this up. Does the ICP/IPR dip a little at high RPMs?
I can't get very high rpm in overdrive because I top out at 92 but it usually shifts at 3k and the lowest the icp got in 3rd gear was the little lag time when switching to OD 2500s
Also my only 3 codes are
One cuz my aih delete
And two about the glow plugs
and that's another issue that is not high on my priority list because it starts very fast even started it in 0 degrees unplugged
Old Feb 6, 2015 | 08:28 AM
  #47
Tugly's Avatar
Tugly
I've never seen my ICP dip during shifts at WOT, unless I let up off the testostobutton - or the ICP died after the shift at lower RPMs. That last part is a problem - the ICP shouldn't drop on an automatic at WOT when the powertrain is 100%.
This is one of those times when I really wish we had a log. We may be looking at tuning differences between an Ex and a truck.
Old Feb 6, 2015 | 09:15 AM
  #48
white Buffalo's Avatar
white Buffalo
Originally Posted by savagebagz
Oh sorry I meant for running the power and ground wires for an electrical gauge.
I used one of the Red, white & blue OEM wires (can't recall which one) for the brake controller that is stuffed behind the dash. If you remove the fuse box cover/panel under the steering wheel you can find them in there up above and to the right of the gas pedal. As for the ground I just used one of the dash frame bolts behind the same panel. Then for the gauge lights you can pop out the headlight switch & run a jumper from there to the gauge lighting wire.
Edit: here's some additional pics:
http://www.dieselmanor.com/diy/PSD3-...73gauge-p2.htm
99StrokeXLT
Jan 30, 2020 01:28 PM
Josh88Ford
Apr 13, 2013 09:37 PM
ronjon95
22
Mar 19, 2011 08:53 AM
TNT in Round Rock
75
Jun 27, 2007 09:36 PM
eric777
27
Jan 11, 2007 04:56 PM
