Sponsored by: Innova
Need some help picking out a sound system
Old Feb 2, 2015 | 09:59 PM
1992f150Hunter's Avatar
1992f150Hunter
I have a 92 f150 super cab with no back seat and I want to put 2 10" subs back there but don't know what the best ones are and what kind of amp and other things im new to this kind of stuff and need some help. Thanks
Old Feb 4, 2015 | 07:05 AM
gman97005's Avatar
gman97005
How much money do you have to spend on car audio ?
For you I would recommend a sealed and loaded enclosure like this..
MTX TNP212D2 Dual 12" Terminator Loaded Sub System
A 4-channel bridgeable class D amplifier in the 800 watt range..
http://www.sonicelectronix.com/item_...a-H4900.4.html
6.5" component speakers from Kenwood, JBL or Rockford Fosgate..
http://www.sonicelectronix.com/cat_i...-speakers.html
If 6.5" speakers won't fit get a pair of 5.25" components..
And some ear plugs
Old Feb 4, 2015 | 02:01 PM
1992f150Hunter
Okay I'll look at them and I'd like to stay under 400 if possible and the door speakers aren't a big deal because the ones in them are pretty good.
Old Feb 16, 2015 | 09:04 PM
lariat97's Avatar
lariat97
I just installed a system in a 93 excab. I used kicker 6.5 twoways in the front doors. They willdrop right in. I am using a 8 inch sub mounted behind the console. This is not my system but it's what my buddy wanted. The CS 6.5s by kicker are $69 at Sonic Electronics. I'd use 2 SoundQubed HDS200 ten inch subs. They are $95 each Put them in a ported box tuned to 40 hz with a 500 watt amp on them & you will be loud. They will take 600 rms Get the soundqubes 750 watt mono amp for $210 & you are setup.
I'm running one Skar vvw 10 inch sub in a 1.25 cubic ft box tuned to 30 hz. It is powered with a JL Audio 500/1 amp. I hit 140db with it
bkpackerfan
Jan 27, 2013 09:01 PM
bigredkacy
Oct 22, 2010 11:23 AM
jayhawk137
20
Oct 1, 2003 07:17 AM
Crimsen
Jun 3, 2003 04:20 PM
explorer92
Apr 25, 2003 05:02 PM
