i have a 69 f-250c.s. all the wiring works except the stuff under the dash.does the dash harness unplug from the rest of the harness. i've seen pictures on another web site but my printer ran out of ink. the wiper doesn't work,signal lights don't work,cab light doesn't work,just got the gauges to work until i hook them up,i can start the truck with the key(new switch),but i have extra wires down below, and a loop of wire on the passenger side of the dash that goes to nothing as far as i can see.,that and used sterring colum,the stearring colum was disassembled and the shift tube take out it might be cheaper to buy a used colum at pull and save for 25 bucks if i do i will get a tilt colum from a 78 or 79 maybe with cruise control on it.
