Brake issues, please help!!
Old Feb 1, 2015 | 01:35 PM
Charles2703's Avatar
Charles2703
Ok, so I don't have any pedal pressure. I have bled the brakes a lot and haves good stream of fluid coming from each wheel with no bubbles at all. Just today I got the fronts bleeding. I had issues getting them to bleed so I took the brake warning switch out of the proportioning valve and messed with it to get the valve to reset (not sure if I even did anything). When I went to bleed the fronts after that I beat on the valve with a wrench. Now the rear brakes and the front brakes shoot a good stream of brake fluid but I still have no pressure at the pedal. I was wondering if anyone thought it could be the booster causing this? When I have the truck running and I press the brakes the engine idles higher so I assumed something was going on there. Any help would be greatly appreciated!!!
Old Feb 1, 2015 | 01:49 PM
Charles2703
Also I unhooked the brake booster and plugged it off and I have plenty of pressure and everything works fine just feels like a truck without power brakes.
lyonsfin
Oct 18, 2017 03:49 PM
Robin13
22
Apr 12, 2016 11:25 PM
Gembone
15
Oct 31, 2015 07:18 PM
Olustee Bus
Oct 18, 2015 04:02 PM
bczolone
General Automotive Discussion
Apr 9, 2009 11:51 AM
