No brake pedal pressure-no brakes - Ford Truck Enthusiasts Forums
Old 10-17-2017, 06:01 PM
lyonsfin lyonsfin is offline
lyonsfin is starting off with a positive reputation.
Replaced MC (forgot to bench bleed) and a couple of wheel cylinders on a 1964 F250 w/drum brakes. I used a vacuum pump to bleed brakes and the fluid looked pretty good. But there is little to no pressure being built up with the brake pedal. Is it the failure to bleed the brake MC or am I just impatient?
Old 10-17-2017, 08:37 PM
FuzzFace2's Avatar
FuzzFace2 FuzzFace2 is offline
FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.FuzzFace2 has a very good reputation on FTE.
Yep!
Pull it off and bench bleed it.
Then with a helper do the pump3 or 4 times, hold, open bleeder, close bleeder, repeat checking fluid level often.
Dave ----
Old 10-17-2017, 09:34 PM
AZ66F100 AZ66F100 is offline
AZ66F100 is starting off with a positive reputation.
What Dave said. That'll get you going.
Old 10-18-2017, 04:14 AM
62fordF250 62fordF250 is offline
62fordF250 is starting off with a positive reputation.
Another major factor is the shoe adjustment. The shoes have to be pretty close to the drum or you'll never get the pressure you should.
Old 10-18-2017, 05:29 AM
Crop Duster's Avatar
Crop Duster Crop Duster is offline
Crop Duster is starting off with a positive reputation.
You can bench bleed the master on the truck by disconnecting the brake line and running a short hose back to the reservoir. Pump slowly until the air is out then reconnect the brake line. If you are using a vacuum bleeder keep in mind that they will suck air around the bleeder screw. So pull about 2 ounces from each wheel and disregard the bubbles. If you still have a little air gravity bleed them but make sure you don't let the master run dry. I almost always work alone, this is the way I do it and it works every time and takes about an hour.
Old 10-18-2017, 04:49 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
Re brake shoe adjustment, what I do is adjust the shoes until a hard hand spin of the wheel results in about 1.5 revolutions. You'll need to fine tune that technique, according to your own strength, but it should be in the ball park.
hydrovac ? jmtbiggin Large Truck 1 11-13-2016 05:16 PM
proper dual res master cyl. function? markeyd 1961 - 1966 F-100 & Larger F-Series Trucks 10 10-30-2016 05:54 PM
Problem with ABS brake bleeding 2001 Excursion 442john Excursion - King of SUVs 10 05-09-2016 10:41 PM
Brake bleeding issue. Possibly mfnheff 1973 - 1979 F-100 & Larger F-Series Trucks 8 04-03-2016 09:28 PM
Diagnosing Brakes / Master Cylinder with Low Pedal AL` 6.0L Power Stroke Diesel 19 02-17-2016 02:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
