Code p0238 but low boost
Old Feb 3, 2015 | 06:36 PM
Quickkfx's Avatar
Quickkfx
Update. Checked for boost leaks. I have a huge leak at the intake manifold I guess is what it's called. The piece that is bolted to the cylinder head. It's leaking on the left head at the rear.
Old Feb 4, 2015 | 09:41 AM
Tugly's Avatar
Tugly
Uh oh. Let me show you what I see in the 7.3L crystal ball.
Old Feb 4, 2015 | 01:55 PM
Quickkfx's Avatar
Quickkfx
Should I buy those manifolds and do both sides or just re-seal the left side that is leaking?
Old Feb 4, 2015 | 02:00 PM
Quickkfx's Avatar
Quickkfx
Never mind I can't use those manifolds. I have a E99
Old Feb 4, 2015 | 06:45 PM
Quickkfx's Avatar
Quickkfx
Found out another interesting thing. Put my chip into stock mode and I hit 18 psi of boost....? Also the waste gate duty cyle was 98.8 idling and 0 when the pedal was to the metal. All the tunes on my chip the waste gate duty cycle was 98.8 no matter what? What does this mean. Chip needs reprogrammed?
Old Feb 5, 2015 | 07:39 AM
Tugly's Avatar
Tugly
At the very least, it needs pulling. Double-check the contacts on the edge of the PCM for corrosion or poor cleaning.
tjmike
Oct 27, 2024 08:25 PM
shockzone
Aug 3, 2009 10:45 PM
HowieE
Oct 24, 2008 10:07 AM
rivrrunner
Apr 5, 2008 08:18 PM
wolfe1104
Jan 7, 2007 12:39 AM
