trouble code p1247 low boost pressure???
Old Apr 5, 2008 | 04:29 PM
rivrrunner's Avatar
rivrrunner
I can't visually see any holes and all boots/clamps are tight with no tell tale soot indication....
Gauge says dumping out at between 18-20......
suggestions ????
Thank you in advance
Brian
Old Apr 5, 2008 | 06:07 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
You are about normal with no tuner. After you get the DP you will push more boost. Turbo don't like more than 25#, I can make 30+ boost.
Old Apr 5, 2008 | 06:52 PM
rivrrunner's Avatar
rivrrunner
Thanx Rick, but why the stored low boost code???
Old Apr 5, 2008 | 08:04 PM
zx250's Avatar
zx250
Of the next Riffraff East
FWIW, stored codes don't mean much, unless you know when it was set. Clear it, run it and see if it comes back. If not, then no worries, if it does then we can start looking.
Old Apr 5, 2008 | 08:18 PM
F350-6's Avatar
F350-6
DH1 DIAGNOSTIC TROUBLE CODE (DTC) P0236, P1247 AND P1248
DTC P0236 indicates a turbo boost sensor A circuit performance concern.
DTC P1247 or P1248 indicate turbo boost pressure was low or not detected.
Possible causes:
damaged MAP hose
low turbo boost
intake manifold or crossover tube hose leaks
damaged MAP sensor
damaged PCM
Inspect MAP sensor hose and manifolds for damage, leaks, restriction and misrouting.
Brian 2002
Dec 11, 2014 04:38 PM
brian1253
6.4L Power Stroke Diesel
Nov 4, 2013 08:32 AM
brian Felts
Aug 16, 2012 11:03 PM
Brian 2002
Apr 12, 2007 01:20 PM
Brian460
Aug 5, 2002 08:31 PM
