Transmission issue, help please!
Old Jan 31, 2015 | 11:10 PM
RankRider68's Avatar
RankRider68
Cool Transmission issue, help please!
My automatic transmission won't grab first gear right away. When it does, the tranny shifts and drives fine. Park it and then try again and the transmission won't grab. Reved the engine a bit then it grabs. Replaced the AT filter (hadn't been done in a long time) added new fluid and still no joy. Your thoughts please
Old Feb 1, 2015 | 02:37 AM
vfelix702's Avatar
vfelix702
Transfer case range fork?
Old Feb 1, 2015 | 06:33 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
what year is your truck,what trans do you have,how many miles are on it and is it the original trans without a reman? what happens if you take off in manual 2? is the fluid level correct?
lets go pats!
Old Feb 1, 2015 | 03:34 PM
RankRider68
It's a 1985 f-250 4x4, exact mileage unknown although I'm pretty sure it's over 150K. I believe that it's the original transmission with a shift kit put in but I have no other information. The symptom is the same in man 1 and 2. Fluid level was down but after I replaced the filter, I made sure the level was correct.The previous owner had only general information to give me about the rig. Should be a good game!
Old Feb 1, 2015 | 08:54 PM
Don Senkow's Avatar
Don Senkow
Assuming the transmission is a c6 and when you put the transmission into a fwd gear there is a delay before the clutch engages, it is likely the forward clutch seal. This usually happens when the transmission is cold, first start of the day. To repair would require rebuilding the transmission.
63falconfutura
May 22, 2015 06:07 AM
qman4467
1983 - 2012 Ranger & B-Series
Aug 27, 2009 09:15 PM
02-Navi
Mar 24, 2008 10:28 AM
Xwarrior86
General Automotive Discussion
31
Mar 24, 2005 07:47 PM
ExplorerSp0084
Sep 26, 2003 04:40 PM
