Why Not?
Old Jan 30, 2015 | 08:16 PM
sean9049's Avatar
sean9049
Why Not?
so it might be a dumb question but i havent seen anything about it, doing e-fuel why cant you just throw a pump on inline, and use the same requlator you have and bypass the mechanical pump?
Old Jan 30, 2015 | 08:26 PM
fordman67's Avatar
fordman67
Its not that easy.
The pump is NOT just in line.
It is dual stage and feeds fuel into filter,back out and then into both heads.
Second is doing the tipical efuel system style gives better filtration than the OE filter yields.
And most importantly declutters the v and eliminates the leak prone system.
Plus you have better control of fuel pressure.
Old Jan 30, 2015 | 08:28 PM
fordman67's Avatar
fordman67
You can do the "tight wad" mod and use the OE regulator in a retrofitted refuel system .
But I sure love my aeromotive regulator!
Old Jan 30, 2015 | 08:30 PM
madMatador78's Avatar
madMatador78
Exactly everything I had typed up and lost.
Old Jan 30, 2015 | 08:32 PM
fordman67's Avatar
fordman67
Sorry Thomas!
Old Jan 30, 2015 | 08:35 PM
madMatador78
It's all good man! Great minds think alike! Had it typed,and tablet goofed. You know how that goes. Lol.
Old Jan 30, 2015 | 09:20 PM
sean9049's Avatar
sean9049
so me, being a "tight-wad" do that mod, and put the filter on my frame,pre and post pump, hook the pump up to my ignition...the stock regulator would be good right? just trying to think of a way to do it for cheap
Old Jan 30, 2015 | 10:10 PM
sean9049's Avatar
sean9049
also would i need to get a sump kit?
Old Jan 30, 2015 | 11:03 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
No sump kit needed.
Old Jan 31, 2015 | 06:37 AM
fordman67's Avatar
fordman67
You can. But bill gets a regulator off eBay that's dirt cheap. All the fittings will be what adds up fastest. I used steel jic fittings from the hydraulic shop with the push loc hose and that saved the bank big! I also used the factory lines just hooking up front in the v and down on the rail before where the soft hose is.
Gettysburg150
Modular V8 (4.6L, 5.4L)
Jun 17, 2019 08:21 AM
dieselsubmariner
28
May 30, 2013 07:35 PM
lazerf250
Jun 18, 2009 06:39 PM
Welk49
Jul 16, 2008 12:05 PM
John311t
Jul 29, 2007 05:56 PM
