1985 ford f150 clutch replacement HELP
Old 01-30-2015, 05:57 PM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
I think if you had firewall tearing you would have no clutch release, not a slipping clutch.
Those prices sound real good.
How much is a rear main seal?
Old 01-30-2015, 07:27 PM
1985tullyhowell's Avatar
1985tullyhowell
1985tullyhowell is offline
rear main seal about 11 bucks one piece
do I have to drain the engine oil to do he rear main seal?
Old 01-30-2015, 07:32 PM
1985tullyhowell
oh and it doesn't like to go into gears sometimes ( when it warms up)
it wont go into reverse ( I get it is a none sychro 1st and reverse but....) at a complete stop it should go into reverse and sometimes it grinds going into other gears shifting normally ( warmed up I have that problem )
Old 01-30-2015, 09:08 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
You shouldn't have any spillage.
The oil level is not that high.
If you have -dis-engagement problems check the pedal shaft bushings and the connection to the master cylinder pushrod.
Does your truck have an adjustable master cylinder?
Old 01-30-2015, 10:03 PM
1985tullyhowell
the clutch pedal assembly , bushings rods ect are good
the master cylinder is non adjustable ( I don't think it is any way from what I have heard)
plus I have scorched the clutch in it several times anyway (hills what not)
plus unknown actual clutch mileage
its been hard to shift at times any way ( I know manual clutches my dads 1967 240 toploader f100 was going bad it acted just like this does - new clutch problem solved)
96F150-4.9
05-12-2016 08:13 AM
turdbird
04-05-2006 06:24 PM
sa_rains
12-09-2005 07:30 PM
mwx4
09-23-2005 09:50 AM
PAUL_2
09-13-2000 08:27 AM
Quick Reply: 1985 ford f150 clutch replacement HELP
