Replacing Fuel Tank Pressure Sensor
Old May 23, 2020 | 03:55 PM
SlowLane's Avatar
SlowLane
All,
They were failing it on the P0446 and the MIL light. I have since gone back and they passed it. It had to be with the cleaning of the Vent solenoid, that I did, that fixed that. Even though it sounds like I did a lot, even went far off base, testing wise, that is the only thing I really saw or made a change in.
Now, could the shops be trying to get more out of me? It is possible. I've been going to this one shop for more than 10 years. Not at all to the other shops. When I went this last time, I had a familiar face. Did that matter? I do not know.
I do, however, still have a P0442. But, no MIL.
I have started on assembling my smoke machine. Then I'll go after the small leak.
I found the following and my torque is now registering like y'all state that yours reads. Did I think it was bad? Not really. I just needed to find the proper way to read it, that made sense, so I could make determinations on that and the other issues.
Mode/PID: 221639
Name: _Fuel Tank Pressure Sensor Volts
Short Name: FTP_V
Min/Max: 0,5
Equation: (A*256+B)/13107
Header: Auto
Diagnostic start/stop: blank
Override PID: blank
I'll post more on what I find later.
Old May 23, 2020 | 05:11 PM
projectSHO89's Avatar
projectSHO89
Most likely, the shop passed it because it finally met the criteria (which it hadn't previously) of no check engine light, no posted DTCs, and not more than one incomplete monitor
Now is the time, unless you want to guess, is to get the smoker previously mentioned, and smoke test the system to find the actual leak.
Your whole premise for resurrecting this old semi-related thread was misplaced, you have a (more or less) simple evap leak.
Glock
1997 - 2003 F150
Jan 5, 2009 02:33 PM
nd925
1983 - 2012 Ranger & B-Series
Sep 23, 2008 03:13 PM
Rick32
1997 - 2003 F150
May 27, 2008 12:33 AM
jayhawkfan
Apr 27, 2004 12:56 PM
mikedevo
Jul 11, 2003 02:20 PM
