Fuel Tank Pressure Sensor
Old Apr 27, 2004 | 12:47 PM
jayhawkfan's Avatar
jayhawkfan
Question Fuel Tank Pressure Sensor
I've had a fuel odor coming from the fuel tank area for some time now. Finally figured out it was the fuel tank pressure sensor mounted on the top of the fuel tank on the white cover that holds the fuel pump, etc. The darn thing broke off where it attaches to the cover. I obviously need to get to the top of the tank to replace it. I've heard pros and cons of both. Is it easier to remove the tank or move the bed back a bit so I can get to the top of the tank?
Old Apr 27, 2004 | 12:56 PM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
Everything I've read indicates that bed removal will be easiest. Remove the bolts securing the bed, the wiring for the lights, and the fuel filler tube/hardware as needed and have a buddy help you lift it off. I'd expect that the spare tire must be removed too.
1968F100ShortBed
2004 - 2008 F150
Oct 12, 2024 04:10 AM
vtgboss
16
May 23, 2020 05:11 PM
jtmalott
Jul 6, 2017 02:35 PM
Jarrett Campbell
Oct 11, 2015 10:46 AM
predaina
29
Mar 29, 2011 07:07 PM
