Sponsored by: Real Truck
2015 backup camera install questions
Old Mar 4, 2015 | 07:01 PM
katoom400's Avatar
katoom400
ended up ordering a new head unit, so I will run the camera to that instead of the mirror.
now to see if I actually have the factory wiring I can tap into or run new wires from the camera all the way to the head unit. if that is the case, what would be the best place to route the wires inside?
Old Mar 4, 2015 | 07:52 PM
Raptorgabe's Avatar
Raptorgabe
I have the wiring to the head unit can I just cut that harness off that specific part and run them tot he new head unit
Old Mar 5, 2015 | 03:04 AM
Raptorgabe's Avatar
Raptorgabe
Well I messed with it tonight and put the green and white to the inside wore of the R a and the brown and violet wire to
The outside wire to the new head unit and wouldn't show anything I can go to the aux in and it shows up just not when u go to reverse just goes to a blank screen ! Any idea why ? I feel like I'm closer lol
Old Mar 5, 2015 | 08:52 AM
rutherk1's Avatar
rutherk1
I just did this exact same thing. Alpine ILX-007 head unit and tailgate camera from CameraSource (270 bucks). I just ran the new harness along the frame up through the cab and hooked it to an up fitter switch. You can also use the center pin wire on the trailer harness if you want it to come on with reverse.
Running along the frame isn't a huge deal. I wasn't able to find a plug and play harness either that was already there from the factory.
Good luck.
Old Mar 5, 2015 | 08:57 AM
katoom400's Avatar
katoom400
so you flip the upfitter switch and the camera automatically pops up on the screen regardless of gear selection?, or you still have to be in reverse and flip the switch?
also where did you enter the cab with the camera-source harness?
Thanks,
Andy
Old Mar 5, 2015 | 09:03 AM
rutherk1's Avatar
rutherk1
Thanks,
Andy
Hi Andy.
I flip the upfitter switch and the camera comes on. I don't have to be in reverse. Nice to be able to switch it on at will to check on the hitch or whatever.
As for coming into the cab... There are 2 ways. Just below the big factory wiring harness that comes through the firewall on the driver side, there is a small grommet that you can use. Since I already used this for my stereo amp power, I went to the big factory wiring harness.
If you look at it from the engine side, there is a little nipple on the top of it. You can clip that off and route wires through there. Nice and clean. That is where my camera wires are going. Then I just zip tied it along some other factory harnesses under the dash up into the camera in on my head unit.
Good luck. Let us know if you need anything else.
Old Mar 5, 2015 | 09:14 AM
Raptorgabe's Avatar
Raptorgabe
so did the harness come with a rca or did u have to make one work ? also how many wires did u have to connect to the stereo I have the switches in my truck also would like to do the same thing
Old Mar 5, 2015 | 09:29 AM
rutherk1's Avatar
rutherk1
Hi There.
Yeah. The camera I got from CameraSource has a nice pre wired loomed harness. Pretty simple. Red, for power (went to up fitter switch). Black for ground. Then an RCA that went to the video on the head unit.
Old Mar 5, 2015 | 02:46 PM
Raptorgabe's Avatar
Raptorgabe
well got into my camera wires coming off are black, black white stripe , white green stripe, purple grey stripe , brown purple stripe so now what I know black is ground , black and white isn't used , white green inner part of rca , brown and violet outside part of rca so the purple with grey stripe has to go to the reverse right
BravoCharlie
Oct 13, 2024 03:06 PM
badranger34
Electrical Systems/Wiring
May 14, 2014 09:03 AM
tractorfan
2009 - 2014 F150
Jul 21, 2013 05:43 AM
TouringMike
Escape & Escape Hybrid
Dec 15, 2012 08:49 AM
johnEboy
Apr 20, 2008 12:34 PM
