Another Cummins Swap...
Old Mar 1, 2015 | 05:58 PM
  #46
xringonly's Avatar
xringonly
co425, Im actually going back through your thread and making notes for reference so kudos to you for providing inspiration and excellent work for the rest of us to aspire to. Gotta give some dibs to Chasetruck also, excellent work, found his tread in a google search, brought me to this site. Thanks guys
Old Mar 1, 2015 | 06:13 PM
  #47
xringonly's Avatar
xringonly
Spent some time cleaning my fuel pump. Lots of elbow grease...and wrist and finger. Before:
After:
Old Mar 1, 2015 | 06:30 PM
  #48
xringonly's Avatar
xringonly
While we are looking at the fuel pump, I pulled the fuel plate. I scribed around the stock, (I assume), location so I could start with the new one there,(benchmark), make adjustments later in small increments so I can note the change if any.
New on the left, Stock on the right
Scribe marks
New plate install in same location
Old Mar 1, 2015 | 07:02 PM
  #49
xringonly's Avatar
xringonly
Painted block back on the stand and tape removed
All exposed holes,(painted), chased with tap again
Also took the time to shim worm gear closer to driven gear on my engine stand, works much better now.
Old Mar 1, 2015 | 07:44 PM
  #50
xringonly's Avatar
xringonly
This is where it gets kinda ify...I was thinking my local hardware store had the bolts for timing case and oil filter/cooler housing, (mini head flanged bolts), but it turns out they only had 1 size and it was too small. I really wanted to get the block assembled today so I had to come up with something else, on a day when nothing around here is open. I decided to give one of the old blacksmith remedies a try. Used motor oil and a little,(a lot), heat. Had to go to work (20 miles each way) and bead blast my bolts, then give them a wipe with acetone. Then on to the grill at 350* for 15 minutes
A little extra heat from a propane torch then dunk in the oil.
Its not really that hot, Only burns after another touch with the torch, let it burn out then reheat and back in the oil. 3-5 times for acceptable color.
First two were for the AFC housing. These two didn't get it but the rest got one time over with scotch brite. Seems reasonably durable but time will tell if they rust.
I use synthetic oil in everything around here, may not have taken so long with used dino oil.
Old Mar 1, 2015 | 07:52 PM
  #51
xringonly's Avatar
xringonly
Still trying to get the short block together at this point, next up, old cam bushing removed:
The old one had just very minor wear showing.
And the new one,
Wont fit!!! I guess its for an oversize application, (spun bearing?)
Old Mar 1, 2015 | 07:55 PM
  #52
xringonly's Avatar
xringonly
That pretty much took the wind out of my sail so I went inside to do some cooking and have refreshments
Old Mar 1, 2015 | 09:35 PM
  #53
co425's Avatar
co425
Nice work on that injection pump, she looks like new. As far as your bolts go, they are unubtainium in the right head. The that's why I just had them stripped and cad plated. It would've cost a mint to replace them for sure.
Old Mar 1, 2015 | 09:47 PM
  #54
xringonly's Avatar
xringonly
Wish there was a place like that around here. Specialty stuff is prob at least two hour drive one way.
Old Mar 2, 2015 | 12:40 AM
  #55
co425's Avatar
co425
And I got extremely lucky with that as well. Cad plating is a dying industry, it's less common then chrome plating even. It sucks because the stuff is a million times more corotion resistant then chrome. The shop that's 10 min down the road is the only one within 400 miles of here.
Old Mar 2, 2015 | 01:42 AM
  #56
oddfordjunkie's Avatar
oddfordjunkie
Turned out nice, what were you using as a cleaner on the IP?
You just reminded me that I need to invest in a blasting cabinet.
Old Mar 2, 2015 | 05:44 AM
  #57
xringonly's Avatar
xringonly
Started out using B-12 Chemtool, spray it on, wait forever, scrub scrub scrub. Weather was yucky outside and it was late. After work the next day I went by an picked up some of this:
The nozzle stops up pretty regular but it will get paint off really quick and doesn't hurt aluminum
Old Mar 2, 2015 | 05:47 AM
  #58
xringonly's Avatar
xringonly
Blasting cabinet, sweet! Previous workplace has a nice large one with vacuum/filter. May try to acquire if they shut down.
Old Mar 2, 2015 | 08:17 PM
  #59
xringonly's Avatar
xringonly
Woohoo! Tool fairy came by today
Old Mar 2, 2015 | 08:21 PM
  #60
xringonly's Avatar
xringonly
Todays small update, old piston cooling jets out, new ones in
The old ones looked fine but hey, I paid for the new ones so...
NOTE: Be sure to take a look thru these when installing, two of mine had loose plastic pieces inside them (obstruction)
