Axle swap
Old Jan 20, 2001 | 12:18 PM
greginboise's Avatar
greginboise
Axle swap
I've got a '75 F100 4x4. The front Dana 44 has drum brakes. A subscriber has a 44 out of a '75 F250 with discs ($400). Is this an easy swap, or should I look for another axle from an F100/150?
Greg
Old Jan 20, 2001 | 01:23 PM
etobolski's Avatar
etobolski
Axle swap
Hello. I don't know what parts you would have to swap to do this, but the F-250 will be an 8-lug axle, and yours is only a 5 lug. It may be easier to just swap an axle from the 1/2 ton truck into yours. If you are near Massachusetts, I've even got one to get rid of. Good luck.
Eric Tobolski
Old Jan 20, 2001 | 03:28 PM
dinosaurfan's Avatar
dinosaurfan
Axle swap
Greg- the thing to do is find a disk brake truck in the salvage yard, 76 or newer, and get everything from the ball joints out. Stick with the 1/2 ton stuff. Your friends f250 stuff will fit on, but then you have 8 lugs in front and five in back and you'd have to buy some new rims. You may want to measure the disk diameters of both 1/2 and 3/4 ton, I don't know if mix and match is possible, but if it is,some of the 3/4's have bigger calipers, if you are needing more stop power. DF
Old Jan 21, 2001 | 09:30 PM
Franklin2's Avatar
Franklin2
Axle swap
Old Jan 22, 2001 | 09:27 PM
hillbillyk's Avatar
hillbillyk
Axle swap
I have a 78 dana 44 high pinion front axle with discs for sale in Maryland
reaperauto1
Sep 7, 2013 09:19 PM
MychalCrowson
Mar 21, 2007 07:42 PM
Broncodawg
Nov 12, 2005 02:54 AM
gbarger
Offroad & 4x4
Apr 9, 2003 11:00 AM
gbarger
Mar 20, 2003 11:49 AM
