Duraspark
Old Jan 26, 2015 | 12:12 AM
BeardedForLife's Avatar
BeardedForLife
Duraspark
Does anyone have any good Wiring diagrams of a 1975 duraspark system, also a good 1975
charging sytem diagram. Thanks in advance!!!!
stuffed a 460 into a 52 F3
Old Jan 26, 2015 | 05:00 AM
Smitty49's Avatar
Smitty49
This is the one I use -
Duraspark II -- The Ford V-8 Engine Workshop
Old Jan 26, 2015 | 06:20 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Stock for 75 would be a Duraspark I. Different control module and the small distributor cap. 77 was the beginning of the Duraspark II. It uses the more standard blue strain relief module and larger distributor cap/plug wires. Either cap/plug wires can be used, but I would use the blue strain relief module. Note the slight difference in wiring. Best to use the Motorcraft module instead of the off brands sold.
Old Jan 26, 2015 | 10:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
DuraSpark electronic ignition introduced in 1974, but not all vehicles came with it until 1976.
1974 DuraSpark ignition module (D4AZ-12A199-C/Motorcraft DY-157-B) is 1974 ONLY!
1975 DuraSpark ignition module (D5AZ-12A199-C/Motorcraft DY-166-B) is 1975 ONLY!
1974 DuraSpark uses the same black dizzy cap (B7A-12106-A) as 1957/74 non hipo V8's.
1975/76 DuraSpark uses the blue H/D V8 dizzy cap (D5AZ-12106-A) that replaced the 1957/74 brown hipo cap (B7AZ-12106-A).
1977 and later DuraSpark uses a much larger V8 dizzy cap that has male ends, snaps onto a plastic adapter located below.
1976/79: There are THREE different DuraSpark V8 modules, but the following is the most common:
1U2Z-12A199-AA (replaced D6AZ-12A199-A & B - D8VZ-12A199-A - D9VZ-12A199-A) .. Ignition Module-blue (Motorcraft DY-893) / Available from Ford & auto parts stores.
Applications: Myriad 1976/90's FoMoCo vehicles / Blue refers to the colored plastic square used to ID modules. It's located above where the wires feed out.
The other two 1976/79 V8 modules have a red square (CA only), or a brown or yellow square (5,000+ high altitude only). Yellow square module replaced the brown module.
Old Jan 27, 2015 | 09:20 AM
04Z06Vette's Avatar
04Z06Vette
Just FYI in case you get stuck. I reused most of the stock 76 mustang harness when I first converted my 49 to a 302. after troubleshooting ignition problem for several hours, I found out that for some 75 and 76 302s, there was a short adapter harness the OEM put between distributer and box. it reversed 2 of the wires. once I put it in place, the engine fired right up.
Old Jan 27, 2015 | 07:35 PM
Flat Ernie's Avatar
Flat Ernie
Just installed a Duraspark II into the 302HO (along with a new gear for the roller cam) that's in my '54 F100. Truthfully, you could get away with one wire - red power to the module (the white one is for starting and not strictly necessary, but it does retard timing slightly)...pretty simple to set up especially with factory harnesses.
Old Jan 28, 2015 | 11:10 PM
BeardedForLife
Thank you guys for all of the info got it kinda figured out now haha. it is very much appreciated as tthis is my first hot rod/ rat rod build.
Pryan68
Jul 16, 2016 03:43 PM
four-sixty-power
Jun 30, 2015 04:52 AM
74 F350 SCS
Sep 12, 2012 09:34 PM
GOVTMOD
Apr 22, 2012 12:43 PM
berry1234
Aug 23, 2010 01:10 PM
