what ignition module is this?
it has a napa echlin sticker on it but no part numbers or anything that i can find. Its in a 68 but i think the motor is a 460 from a 70s truck thats why im posting here. i could not find anything with this red-white-green-black-purple-orange wire pattern.
Any help would be appreciated
Blue = the most common (and best) Dura-spark II module. Used on a ton of applications from '76 up till I believe late 80s early 90s.
Also, the wiring is pretty much standard Dura-spark II. The purple, orange and black go to the distributor pick up, the green to the + terminal on the ignition coil and the red and white go to the ignition switch.
BTW, welcome to FTE, lots of good, knowledgeable people here.
Ignition modules, 74 (black grommet) and 75 (green grommet) are year specific and will not interchange. 76 to 79 (blue grommet) are interchangeable.
Ignition modules: 1974 is 1974 ONLY / 1975 is 1975 ONLY.
Blue module introduced in 1976 was used well into the 1990's.
D4AZ-12A199-C 1974 only.
Dura Spark ignition modules identified by a colored plastic insert located above where the wires feed out.
2 others: One has a red plastic insert, the other has a yellow or brown plastic insert.
Red*module is D7AZ-12A199-A*used in some CA vehicles ONLY.
D9AZ-12A199-C(replaced D8AZ-12A199-A). One of these modules is yellow, one is brown. Since the part number was replaced, I cannot recall which module was which color.
These modules were used in 1978/79 302 & 351M/W vehicles sold in high altitudes only.
351W: Passenger Cars & Econolines only.
1U2Z-12A199-AA(replaced D6AZ-12A199-B - D7AZ-12A199-B - D8VZ-12A199-A - D9VZ-12A199-A) .. Ignition Module -blue insert (Motorcraft DY-893) / Available from Ford.
Myriad 1976/90's FoMoCo vehicles.
Green Sales in OH.
Collectors Auto Supply in WA.
Haven Ford in KS.
Klimesh Motor Sales in IA.
Bob Allen Ford in KS.
Freese Motor Inc in IA.
Wesley Obsolete Parts in KY.
Dennis Carpenter Ford in NC.
