EBPV delete question
Old Jan 25, 2015 | 11:03 PM
cps's Avatar
cps
Well having gone thru my 3rd turbo in 2yrs now I am wondering if there are any negative consequenses to plugging off the ebp valve with regards with turbo lubrication? I am getting real good at taking the turbo off and on now. I am thinking I may have done something wrong.
Thanks for any comments or advice,
Roy
Old Jan 25, 2015 | 11:16 PM
white Buffalo's Avatar
white Buffalo
Roy,
maybe you should try the non-ebpv pedestal? I used this pedestal on my Excursion for 3 years with no problems, I've had the modified stock pedestal on my F-250 for 8 years with the van turbo as well. So, I'm not sure what went wrong with yours - but at least with the non-ebpv pedestal you remove that variable.
Garrett Early 99 Non-EBPV/ Blank Pedestal - Riffraff Diesel Performance
Old Jan 25, 2015 | 11:33 PM
cps's Avatar
cps
thanks for the suggestion. I am leaning toward that solution. But here is the deal, The last time it went was last September. Pulled it took, took it back to the shop and they said bearing/seal failure was caused by contaminated oil. So I get an OA done of course, comes back perfect. The only thing that was above specs was high copper(turbo bearing).Then they say ,oh that is a performance turbo no warranty. WTH! Any who, they rebuild it now it is gone 4 months later.
Old Jan 26, 2015 | 11:13 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
I have not rebuilt a turbo or have a lot of hands one experience with them, but if I need to I will do the job myself. It seems like you should go the same route, time permitting of course. I would highly suggest not taking it to the "shop" and do the repair/rebuild yourself so you know it is done right.
Old Jan 26, 2015 | 12:30 PM
holeshotwalt's Avatar
holeshotwalt
Look for this guy on ebay or call his number. He's a straight shooter with info, or he'll sell you the parts to do it yourself, or he'll do the rebuild...
Rons turbo service 801-842-9186
Emel
6.7L Power Stroke Diesel
Nov 14, 2016 07:07 PM
WatsonR
Nov 7, 2014 07:05 PM
ford7.3l
Feb 12, 2014 10:04 AM
quesey
Jun 3, 2013 03:19 PM
RunRed
General Diesel Discussion
Jan 29, 2008 09:53 AM
