I broke more stuff
Old Jan 25, 2015 | 06:05 PM
77_f250_custom's Avatar
77_f250_custom
I broke more stuff
Well fellas, I decided to change out my steering gear (originally just the drag link, then the tie rods and sleeve as well. They were all shot.) When I went to remove the drag link from the pitman arm, it came off but the stud stayed in the pitman arm. I tried the separator fork, I heated the pitman arm with a torch, I beat on it with a hammer....That stud will NOT move! Any thoughts on fixing this dilemma, short of poking a hole in the gas tank and starting a fire underneath it? I've been at this for days and its driving me nuts. (I'd also like to avoid putting in a new pitman arm if possible.)
Old Jan 25, 2015 | 07:29 PM
Jdeshler's Avatar
Jdeshler
Shoot us a picture if you can and well see what we can do!
Old Jan 25, 2015 | 07:32 PM
HIO Silver's Avatar
HIO Silver
I'd pull the steering box and work on it on a bench.
PB Blaster, a gear puller, and patience.
Old Jan 25, 2015 | 07:35 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
If PB blaster and a fork was no luck, ever heard of CRC Freeze Off? It might be worth a try before you torch it...lol
Old Jan 25, 2015 | 07:45 PM
Jdeshler's Avatar
Jdeshler
I understand a picture may not be possible, what's the problem? Is the pitman arm stuck on the sector shaft?
Old Jan 25, 2015 | 07:55 PM
77_f250_custom
No the pitman arm isn't stuck on the shaft. The stud from the drag link is stuck in the pitman arm (on the end that isn't attached to the steering box). I'll try and get a picture tomorrow. If I can't get the stud out with a gear puller tomorrow, I'll pull the pitman arm off and take it in to school and have it pressed out.
Old Jan 25, 2015 | 07:56 PM
77_f250_custom
By the way, I haven't heard of the freeze off stuff. Hows it work?
Old Jan 25, 2015 | 07:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Draglink is 3304 .. Pitman Arm is 3590
jerryst
Nov 15, 2016 09:10 PM
Road Warrior 95
Jul 5, 2014 09:55 AM
ichabod40
Jun 21, 2010 09:31 PM
fordguy300
Mar 21, 2009 12:52 AM
zfifty
Dec 9, 2006 09:46 PM
