Pitman Arm Removal
Old Jun 13, 2010 | 03:18 AM
ichabod40's Avatar
ichabod40
Pitman Arm Removal
I'm having issues removing the pitman arm from the steering gear from my '93 f-250 4x4. I've pulled the steering gear from the truck already because it is getting replaced, but I can't get the pitman arm off of it. I tried a puller, a pickle fork, kroil, and pb blaster. My question is if I put a torch on the pitman arm to help break it free, is it going to ruin/weaken it?
Old Jun 13, 2010 | 04:02 AM
Lazy K's Avatar
Lazy K
A good puller wound up tight and then a good hard hammer blow on the puller bolt head usually works.
However if all else fails then use heat, it should not damage the arm.
Old Jun 13, 2010 | 03:08 PM
jas88's Avatar
jas88
Lazy K is right, tighten up the puller and hit the pitman arm on the side a couple of whacks, then retighten. Repeat this a few times and it will come off I bet.
Old Jun 13, 2010 | 05:27 PM
fishforlife2007's Avatar
fishforlife2007
jas88 is rite there. that should work. if not soak it in some pb. come back in an hour, heat the pitt. arm, and it should come rite off.
Old Jun 21, 2010 | 09:31 PM
ichabod40's Avatar
ichabod40
Thanks guys. It worked like a charm, didn't even need to heat. Should have known I just needed to hit with my 4 lb. sledge.
catzr440
Oct 19, 2016 01:03 PM
Road Warrior 95
Jul 5, 2014 09:55 AM
gofrogs69
Jan 2, 2013 01:52 PM
74fordhighboy
Jun 16, 2010 08:46 AM
zfifty
Dec 5, 2006 09:20 AM
