351M timing issue
Old Jan 25, 2015 | 03:57 PM
1979 300i6's Avatar
1979 300i6
351M timing issue
My initial timing using a light at idel with the vacuum advance disconnected is 12 degrees TDC, but with it connected it stays at the BTC mark at idel, I am new to timing an engine and could use some advice on what to do, its got a 1406 edlebroke and 4 barrel intake, not sure if it has a aftermarket cam or not as I bought it not running it was supposed to have been rebuilt. Thanks
Old Jan 25, 2015 | 04:22 PM
Tedster9's Avatar
Tedster9
The timing shouldn't (necessarily) move at idle spec with vac advance connected to a ported vacuum source. If you were to rev the motor up you'd see the timing advance from both the mechanical and vacuum advance mechanisms doing their thing.
Old Jan 25, 2015 | 04:23 PM
gatorfor88's Avatar
gatorfor88
Are you saying when you reconnect vacuum line to advance it doesnt change? It should not change at idle if you are hooked up to ported vacuum. When you give it throttle then the vacuum advance should do what it is supposed to do and advance the timing. If it is not doing this then you either have a bad vacuum advance diaphragm, no vacuum at your port or possibly a vacuum leak.
Old Jan 25, 2015 | 04:42 PM
Tedster9's Avatar
Tedster9
Yes, if you have a pump you can watch the breaker plate move with increasing vacuum. Or use a piece of clean hose and draw on it like a straw. If the idle is set real high, the vacuum advance might start to come in. Normally, at idle spec there is little to no vacuum from the ported outlet. Disconnecting and plugging the vacuum advance hose is just good practice and eliminates this a source of bogus numbers. It depends on whether we are talking a sewing machine at 500 RPM or a fire breather that won't "idle" below 1100. Most people want to use ported "spark" vacuum source.
Old Jan 25, 2015 | 06:03 PM
1979 300i6's Avatar
1979 300i6
My vacuum advance is on the carb, and the idel changes drops from 900 rpm to about 650 when disconnected
Old Jan 25, 2015 | 06:20 PM
Tedster9's Avatar
Tedster9
Well, my advice would be to follow the procedure in the manual. I bet it's online somewhere if you dig around. It takes all that into account. For that matter engine base timing doesn't change unless somebody changes it, and generally speaking no reason to change, unless one is certain what they are trying to do. Base timing changes means carburetor idle mixture settings need to be reset.
Set the base timing with the vacuum advance hose disconnected and plugged and at the specified idle, this is important. Make sure the vacuum advance diaphragm isn't leaking, and reconnect. Then follow the carburetor adjustment procedure and you should be good to go.
Old Jan 25, 2015 | 06:32 PM
Chris Popanz's Avatar
Chris Popanz
if youre running the stock DII dizzy, you can adjust it with a very small allen wrench going thru the vacuum port on the dizzy. maybe someone cranked it up not to engage at all.
Old Jan 26, 2015 | 12:23 PM
1979 300i6's Avatar
1979 300i6
My vacuum advance line is connected to the drivers side front port on the 1406 and it draws vacuum at idle, I switched it over to the passenger side which does not draw vacuum and it idled slower and the timing stayed at 12 degrees, what's all this mean? And which port should I be running my advance on? Thanks.
Old Jan 26, 2015 | 12:32 PM
Tedster9's Avatar
Tedster9
Heh. "What oil is best"? Usually ported vacuum is utilized to keep a steady idle. Manifold or constant, vacuum source is also used by things like air conditioning, A/T, and other vacuum operated solenoids and adversely affects idle. That's actually why ported vacuum was first utilized, steady idling. You'll hear people dismiss it as a "smog" era atrocity but it's been a part of carb design prior to 1950.
Lumpy cams in highly modified engines usually require using manifold vacuum because they won't idle smooth at a low RPM. Using manifold vacuum can allow for a smoother idle if there aren't other engine vacuum devices competing for it, and cooler engine temps. It kind of depends on your application. At anything above idle RPM it isn't going to matter much and the advance will be the same.
Old Jan 26, 2015 | 02:58 PM
gatorfor88's Avatar
gatorfor88
Normally ported vacuum is recommended for vacuum advance.This means it does not draw vacuum until you start opening the throttle. Which means your base timing is set up with no vacuum, and it only starts to advance as needed with throttle.
Old Jan 26, 2015 | 03:42 PM
Tedster9's Avatar
Tedster9
One thing it took me a while to figure out is how misunderstood vacuum advance is. It usually gets unhooked at the first sign of trouble. That's not a bad plan for troubleshooting, in order to remove a possible source of vacuum leak. But unless you're a WOT all the time drag racer, you want vacuum advance, and you want it to work right.
Old Jan 26, 2015 | 04:07 PM
tbear853's Avatar
tbear853
As to timing a 351m, mine has Edelbrock Performer Intake and 1405 Carb (with Holley 12-803 FPR at 5.5 psi), old Crane Fireball cam (near same specs as popular "torque" cams I notice) and a OEM distributor fitted with a quick advance kit since 1986. I let her idle at about 900.
To time it, I disconnect the vacuum line at the distributor and close it off (plug) and loosen distributor and speed up motor to where timing no longer advances with more RPM (which is pretty quick with lighter advance springs) and set timing at 34-35 degrees BTC total advance (I have my balancer marked up to 50 degrees BTC). That's the most it'll see under load when no vacuum is available to pull the vacuum advance more. It might stand more but it don't ping at that setting.
Then I "unplug" the vacuum line and reconnect it to distr. and check just to make sure it's working, not unusual to see over 50 degrees at higher engine speed when closing throttle and vacuum is higher, but then the engine is not loaded so no ping no problem.
A good vacuum advance is absolutely essential if you care about gas mileage. Currently mine get's it's signal off ported port on carb intended for distributor vacuum suignal .... but I have used straight manifold vacuum with some setups, but the idle screw must be backed off and some setups don't like that as well.
kvolland
Nov 16, 2009 02:13 PM
EDMist
Oct 28, 2009 01:02 PM
51merc
Jul 6, 2008 08:24 PM
steeldust
May 17, 2004 05:40 PM
spikedog
Oct 25, 2003 12:50 PM
