engine vacuum at idle??
Old Jul 6, 2008 | 02:21 PM
51merc's Avatar
51merc
HI Guys and Gals...
The motor (if youve been following the saga...lol) is a stock 51 Merc. flathead., no mods except the 6volt electric fuel pump.
Just put in points, condenser, coil, wires, cap and rotor. Gapped the points to .014 as per manual.
Have been reading the search and internet as how to use the vacuum gauge to set the timing. Twist distrib. until highest vacuum is achieved, back off 1 inch and tighten her down. Also read that total vacuum should be 22 degrees at 2500-3000 rpm.
Here is the thing. At idle, i am only at 14-15 inches. Some websites say a good running engine should be at 20. I turn the distrib. and can't get anymore vacuum.
Any help would be greatly appreciated.
Thx in advance...
Rick
Old Jul 6, 2008 | 04:13 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Total vacuum advance should be about 22 deg, under load, at 2,000+ RPM; you won't be able to duplicate that in the driveway. You would have to use a vacuum pump on the advance can. The workshop manual gives the amount of advance at different levels of vacuum.
The manifold vacuum quoted (20") is pretty high IMO, and is surely at sea level. What elevation are you? I am at 5500' and never see anywhere near that, I think 15" would be reasonable here. Besides setting the timing based on vacuum readings, usually you have to drive it and listen for pinging and make adjustments downwards.
Old Jul 6, 2008 | 05:57 PM
Julies Cool F1's Avatar
Julies Cool F1
Hi Rick!
I used this method to confirm the timing on my 390. Come to find out that all the modern books had it set at 6 deg BTDC. They failed to mention that this was with the Thermactor (pollution control) installed (which I don't have). I had to find a pre 1967 book to get the real value at 12 Degrees (with an advance as far up as 17 for performance if desired). It made a TREMENDOUS difference in how that engine ran.
Anyway, the actual vacuum value when looking for correct timing is somewhat mute. What you are looking for is the HIGHEST vacuum you can get.
Now this also requires some other jimmying. You have to keep the idle at the right rpm, and you need to tweek your idle mixture while doing it as well. So it's actually a matter of fine tuning about three things in conjunction while setting timing.
When you are satisfied that you have done all that, THEN back the timing off to reduce the vacuum by 1 inch.
I'd check it with a light after to compare the running engine with the book value as well.
J!
Old Jul 6, 2008 | 08:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Just remember that flatheads don't need or like a lot of advance. Too much will just make it run hot.
midgainc
37
Aug 7, 2014 08:37 PM
drusher
15
Jul 24, 2014 04:38 PM
64F-100
Oct 12, 2010 12:31 PM
MattP51
32
Sep 11, 2006 04:38 PM
stevieweevie
Jul 29, 2005 09:52 AM
