Self-adjusting mechanical clutch??
Old Jul 29, 2004 | 11:14 PM
fordflaresides's Avatar
fordflaresides
Today I push the clutch pedal in, start the motor, go to take off and I've gone from about 2 inches of freeplay at the bottom to about 4-5 inches of freeplay. The clutch still engages fine and has some freeplay at the top but I read that if there is not enough freeplay at the top it will press on the pressure plate and burn the disc up. Anyone have any idea where this extra freeplay came from, should I be worried? It actually feels right compared to newer trucks I've driven but I'm baffled as to where the extra freeplay came from all the outside linkage is there and the bolts on the rod that pushes on the fork are tight.
Old Jul 31, 2004 | 02:50 PM
fordflaresides
No one has any ideas as to what happened?
Old Jul 31, 2004 | 03:59 PM
lee's Avatar
lee
Fordflareside,
You mean that this happened overnight? Ok one day then this way the next?
If so, then I would get under the truck and look at the clutch linkage. Bent linkage rod maybe? Grasping at straws here, Does the bottom of your bellhousing have an inspection cover that you can take off? If so, take it off and have a look inside. Maybe the pivot point that the clutch fork pivots on has broke off. This can happen though not likely.
Good luck,
Lee
Old Aug 1, 2004 | 02:34 AM
fordflaresides
Yeah, it just happened overnight, none of the external linkage is damaged. No inspection plate on clutch housing, clutch still engages/disengages fine so I'm just puzzled as to where the extra freeplay came from.
DanielT28
33
May 10, 2014 02:28 PM
ola1234
May 22, 2011 08:11 AM
KillerTux
May 6, 2010 01:22 PM
matpasch
Aug 22, 2009 07:06 PM
gui88ford
1997 - 2003 F150
15
Jul 25, 2006 11:43 AM
