Flat-6'ers take note!
Old Jan 24, 2015 | 03:34 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Manifold, Intake, Flathead Ford F6, 254 Six
No affiliation... Ray and I were discussing the fact that the 254 and 226 would have different manifolds, so I looked it up in the parts manual. Sure enough, they are different, and the carbs are different, but I can't tell exactly how much bigger (if any) the 254's carb is. Could be the secret to unlocking the awesome power of the flat-6!
Old Jan 24, 2015 | 06:35 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Ross,
I think you need to ditch your truck and step up the beauty of the monkey face trucks. Then you can build a flat 6 with the bigger carb and give us an amazing write up.
Come on man, you know you're just dying for another truck
Bobby
Old Jan 24, 2015 | 07:10 PM
sere0501's Avatar
sere0501
Originally Posted by bobbytnm
Ross,
Bobby
I'll second that!
Old Jan 24, 2015 | 07:23 PM
bobj49f2's Avatar
bobj49f2
That's a nice intake for the money. The real gem would be the exhaust for the same engine.
Old Jan 24, 2015 | 08:46 PM
tinman52's Avatar
tinman52
Welder User
I have a 254 carb I could measure if anybody needs to know. I know the bolt spacing is different between the 2, not sure if the carb bore is...
Old Jan 24, 2015 | 09:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I think the hot setup would be to put the Holley 94 from the V8 on an adapter. This manifold could make use of the added flow.
Old Jan 24, 2015 | 09:14 PM
havi's Avatar
havi
I'll have the Roast Duck
physically, the intake manifolds interchange between the 226 and 254. However, the 8MTH casting is on the intake, and so something must be different. I would guess it's the intake port size. Or could be the carb base. I have both, so I could compare them come Spring. I'm sure that manifold will be sold by then, lol.
Old Jan 25, 2015 | 07:28 AM
4tl8ford's Avatar
4tl8ford
The carb repair kits interchange and I think I saw (it was late) that the carbs were the same 0 Have to do some squirreling thru the files to day
Old Jan 25, 2015 | 09:01 AM
38 coupe's Avatar
38 coupe
I didn't realize the manifolds were different. Next time I am at dad's shop I will look at the 226 and 254 I have sitting there and see if I can figure out the differences.
Old Jan 25, 2015 | 12:59 PM
52 Merc's Avatar
52 Merc
Both the 226 and 254 use the same intake and exhaust gasket set, which tells me the ports are likely the same. The differences in the intakes probably have more to do with the fact the 254 had a governor under the carb, possibly needing a different base and studs to accommodate, and vacuum outlets for power brakes that the 226 models may not have had drilled.
Old Jan 25, 2015 | 01:38 PM
havi's Avatar
havi
That makes more sense to me, now that you mention it.
Here's a pic of the 226 and 254 intakes. Notice the 254 has a bigger port for the hydrovac. and the 226 has a smaller vac port higher up and straight out the back.
Old Jan 27, 2015 | 01:43 PM
4tl8ford's Avatar
4tl8ford
Flat Six Carb Info here
https://www.ford-trucks.com/forums/1...carb-info.html
Old Jan 27, 2015 | 02:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
So the 254 does have a bigger bore at the manifold. Perfect for a turbo application!
minnesota-clint
Feb 9, 2012 09:44 AM
BlueTorpedo85
Aug 25, 2006 07:11 PM
hornbymatt
Mar 17, 2006 02:16 AM
Nateid15
29
Sep 6, 2005 06:49 PM
OneFine69
May 21, 2004 11:27 PM
