Modular V10 (6.8l)
V-10 swap
Old Jan 21, 2015 | 11:43 PM
Ohiostate1's Avatar
Ohiostate1
V-10 swap
Having problems with my 99 6.8 . Found a 2006 3 valve 6.8 can it be swapped in my 99 ? Also it was never in a vehicle it was used on a genrac generator and run on LP ! Can this be done ? It's a really good deal if it will work thanks for any and all help and info !
Old Jan 22, 2015 | 03:34 AM
Bently_Coop's Avatar
Bently_Coop
Different transmissions. 99-04 use a 4R100 and the 05+ use a 5R110. Not sure about the wiring and mounts.
Old Jan 22, 2015 | 05:24 AM
Ohiostate1's Avatar
Ohiostate1
V-10 swap
ok thank u looks like I'm on the hunt again ! Was hoping it would work the motor only had 10 hrs on it for $1200
Old Jan 22, 2015 | 08:43 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Hmm... a 3-valve, running on LP. Take many many many pictures of the intake and post them here
One of the biggest problems with transplanting a 3-valve motor into a 2-valve truck was the variable-volume intake plenum setup and how it requires a 3-valve computer to control it. It would be very interesting to see what kind of intake that industrial V10 uses.
Old Jan 22, 2015 | 08:54 AM
krewat's Avatar
krewat
Actually, are you SURE it's a 3-valve? Plastic or aluminum valve covers?
Old Jan 22, 2015 | 12:22 PM
Ohiostate1's Avatar
Ohiostate1
Looked like plastic , actually the intake looked like mine too ! I have a few pics they r not real clear but I'll try and post them . So there might be a chance it's not a 3valve , if it's not will it bolt to my Trans in my 99 ?
Old Jan 22, 2015 | 01:07 PM
krewat's Avatar
krewat
If it's a 2-valve, it'll fit - and all the sensors should hook up ...
I'm trying to remember the one thing different between the pre-2000 non-PI, and the 2000-up PI-head V10... someone mentioned a certain sensor was in a different place.
Do you have an EGR valve?
Old Jan 22, 2015 | 03:43 PM
Ohiostate1's Avatar
Ohiostate1
Where should I look for the egr valve ? If it a 3 valve would I be able to tell by looking in the exhaust port ?
Old Jan 23, 2015 | 08:25 AM
krewat's Avatar
krewat
I think the EGR is on the back of the intake.
Plain and simple: Plastic valve covers is 2-valve, aluminum is 3-valve.
Old Apr 22, 2015 | 02:11 PM
Ohiostate1's Avatar
Ohiostate1
Well it's been along couple of months but we finally got my industrial 08 v-10 swapped into my 99 v-10 truck ! Had to swap the timing cover , oil pan and pick up , oil cooler , water pump , and re route the heater hose , and spark plugs , but it's all in and runs perfect ! Thanks for all the help ! It was a pretty big job !
Old Apr 22, 2015 | 03:05 PM
speakerfritz's Avatar
speakerfritz
when you have enough post to be able to PM and send emails...can you send me info on where the engine is and contact info.
Old Apr 22, 2015 | 03:56 PM
Ohiostate1's Avatar
Ohiostate1
It was in poseyville Indiana , I bought one and he has another but no intake , my 99 intake won't fit on it . Doug's standerd is name of the place 812-874-3419
Dowdy2
Modular V10 (6.8l)
Dec 15, 2010 04:11 PM
nicebenz68
Engine Swaps
Mar 9, 2009 12:37 PM
TODD LYND
Modular V10 (6.8l)
17
Feb 25, 2007 01:42 AM
bigolfordtruck
Aug 14, 2006 09:42 PM
