2001 F350, 153K, 7.3L.
Recently been feeling a slight vibration in the front end/steering. Increases with speed. Doesn't "wiggle" steering wheel, more like a vibrator is connected to it. Early sign of bearings?
Last summer put new rotors/pads on.
No . . . I don't know what that is. I know what a wheel balance is. And a wheel alignment.
Also, I have not hit any severe pot holes or curbs or anything. I'll find out & check that.
Drive-line-induced vibrations (u-joints, center carrier bearing, etc.) typically show up around 35-40 mph and go away after about 70 mph. They also typically only vibrate when under load, so if you get off the throttle on a level or down hill run and the vibration suddenly goes away, and then comes back as soon as you hit the throttle again, it is most likely drive-line related.
F250 . . . it does seem to start around 40 and on to 50mph. Haven't had it on the freeway yet to go faster. However, I had the U-joints replaced in June of 2001 by a pro. Will check carrier bearing AND SUCH. Thanks.
Also noticed the vibration would subside when brakes were applied(?)!
Allright . . . no play in u-joints, carrier bearing, and no drive shaft weights are gone . . . but a front tire was about 16 pounds lower than the others.
I will get that fixed, then rotate those fronts to the back, and see if the problem still occurs.
