steering wheel vibration
Steering wheel vibration at around 40 mph, no vibration between 50-60 mph. At 60 mph + slight vibration and a low hum (sounds like running large mud tires)
Replaced front right wheel bearing was loose,and rotated tires (didn't balance yet) didn't solve. Greased all front end fittings - improved on hwy but didn't solve.When I let go of wheel it pulls to the left. Could this problem be in this order: Tire(s) out of balance, alignment, ujoint/carrier bearing, ball joints, torque converter, steering stabilizer, rear diff, ipr, transmission?
vibration is only on wheel, not on floor, or pedal
