batteries?
Old Jan 19, 2015 | 05:01 PM
dgulledge's Avatar
dgulledge
batteries?
04 f250 6.0 late 04 engine. I had a no hot start problem so I changed standpipes and dummyplugs.found out I had diesal in my oil so I changed all eight injector orings. Then starter went out so installed a new starter. Truck started and ran fine for two weeks. Stopped the other day truck wouldn't start when I went to leave. let it cool off started right up. Engine turns over at 160 rpm when cranking when hot so icp is only at 260 psi. I charge or jump the truck off it starts right up.could my batteries be going bad?
Old Jan 19, 2015 | 05:42 PM
KDAVID1's Avatar
KDAVID1
260 is half what is needed
You still have a HPOP leak.
An air test would be in order
2006 F350 4X4
Old Jan 19, 2015 | 05:45 PM
dgulledge's Avatar
dgulledge
That's what I thought
dgulledge's Avatar
dgulledge
Were else counder it be leaking?
Old Jan 19, 2015 | 05:58 PM
69cj's Avatar
69cj
STC fitting.
Old Jan 19, 2015 | 06:12 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Originally Posted by 69cj
STC fitting.
No STC fitting on a 2004...
Josh
Old Jan 19, 2015 | 06:13 PM
dgulledge's Avatar
dgulledge
I have a late 04 with the icp sensor on the right valve cover
Old Jan 19, 2015 | 06:40 PM
dannyboy950's Avatar
dannyboy950
You still wouldn't have a stc fitting they did not come out till 05.
Old Jan 19, 2015 | 06:50 PM
dgulledge's Avatar
dgulledge
Good one less thing to worry about. Can I get the ball tube seals from advance
Old Jan 19, 2015 | 07:24 PM
Bullitt390's Avatar
Bullitt390
Bad HPOP shaft seal is likely you're issue.
Park nose down and it'll start right up. Park nose up and it'll be a long crank.
Josh
Old Jan 19, 2015 | 07:27 PM
dgulledge's Avatar
dgulledge
Nose up or down doesn't make a difference. I tried it both ways
Old Jan 19, 2015 | 07:39 PM
dannyboy950
Untill you do the air test all we can do is best guess or see some actual values.
Bullit mentioned a fairly common failuer of your type pump.
Old Jan 19, 2015 | 09:21 PM
jmtbiggin's Avatar
jmtbiggin
Josh
Would that be a leak that would drip on driveway,or an inside leak?
Old Jan 19, 2015 | 09:23 PM
Bullitt390's Avatar
Bullitt390
Internal leak from the HPOP seal. The reservoir empties and causes a long crank.
Early pump is very common to have a failed seal.
Josh
6.9lbluenose
Jun 9, 2019 07:48 AM
BigWhite94
Jun 7, 2011 11:16 PM
sullyt28
Aug 21, 2010 09:26 PM
brutus_jr
Apr 1, 2010 09:52 AM
