Speedo Gear
Old Jan 20, 2015 | 02:50 PM
Shadowrider123's Avatar
Shadowrider123
Some Ford tucks came with 3.00 or 2.75 gears and tires around 29 inches tall.
It would seem my speedo is to far off to be just a rear gear change.
ND: I have a 1964 F100 292/COM, 3.10 rear gear, L78 bias tires (29.3in).
banjopicker66's Avatar
banjopicker66
Another option is to change the driving gear, which is usually ground into the output shaft.
Which means removing the transmission to disassemble it, and replace the output shaft as part of the reassembly.
One more option would be to change the rear axle ratio, which is easy enough to do if you can find a third member with the necessary ratio. In this case, though, the required ratio would increase RPMs at equivalent speeds.
Old Jan 20, 2015 | 03:20 PM
Shadowrider123
I want to remove 1 bolt and a c-clip to fix this issue.
Transmission removal/disassembly and gear changes are not going to happen to fix a actual/indicated speed issue.
Old Jan 20, 2015 | 03:47 PM
Shadowrider123
I have done some more research.
It seems the speedo needle is not driven off the cable, but has an induction pickup.
My problem may be that the assembly is dirty and the needle is hanging up.
I need to remove the cluster anyway to install the gasket around the bezel, so I will check that out.
Old Jan 20, 2015 | 05:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Shadowrider123
I have a green 17 tooth gear.
Is there a 12 or 13 tooth gear?
No, 16 thru 21 teeth are all that FoMoCo offered.
Zachthemoo2
Oct 2, 2014 04:42 PM
kevinfelix
22
Aug 1, 2011 03:06 PM
DutchmanAZ
Jun 9, 2010 02:10 PM
PetesPonies
Jun 2, 2010 11:04 PM
yellow72f100
Nov 2, 2005 06:52 PM
