Need transmission help
Old Jan 19, 2015 | 12:54 PM
Scottybclarky's Avatar
Scottybclarky
I bought a 1965 ford f100 a ehile ago as a project. One of the peices that i needed was a new transmission. I found one that was supposed to fit right in off of a 64 f100 but the bell housing was different. I need to know what kind of bell housing i need to make this all fit together. I have an inline 6 240 engine and the code i got off the new transmission is "C3TR-7A040-C W-1". It is a 3 on the tree. Any help would be greatly appriciated.
Old Jan 20, 2015 | 08:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Scottybclarky
I bought a 1965 F100 240 I-6 a while ago as a project. One of the pieces that I needed was a new transmission.
I found one that was supposed to fit right in off of a 64 F100 but the bell housing is different.
I need to know what kind of bell housing I need to make this all fit together.
What's wrong with the bell housing your truck has now?
The code I got off the new transmission is "C3TR-7A040-C W-1". It is a 3 on the tree.
This is not the code for the trans. It's the casting number located on and for the extension housing itself.
Welcome to FTE
Is your F100 2WD or 4WD?
1965/79 F100 2WD 240/300 I-6 uses a different bell housing than 1957/64 F100 223 I-6.
If this trans is from a 1957/64, it will not bolt to the 240's bell housing, as the case is different.
The TRANS ID tag was originally bolted to the back of the trans where the extension housing bolts on. It's probably missing by now.
What's wrong with the trans that your truck has now?
Old Jan 20, 2015 | 12:35 PM
banjopicker66's Avatar
banjopicker66
Scotty: Welcome to FTE. You will find a great deal of knowledge and experience here. Of the '61 to '66 Slicks, you have one made in the best years: '65 and '66.
I am sorry to hear that you were sold a transmission that will not work in your '65.
For future reference, it will help to use only '65 and later parts.
Although '64 and earlier trucks look like '65/'66, the similarity is only skin deep, and only in a few parts.
In '65, Ford introduced the Twin I-beam suspension, which meant changing almost everything. Steering, suspension, drivetrains, the frame and even the cab itself will not interchange after '64. (There are a few things that will interchange, such as hoods, fenders, and the back half of the '64.)
The good news is that you can do great upgrades fairly easily from trucks up to '79. The Twin I-beams and the front half of the frame stayed the same dimension wise, so transplants are pretty easy to do.
The 3 speed you need is a Ford 3.03, and is pretty common.
Best of luck to you, and again, Welcome to FTE!
Old Jan 20, 2015 | 02:55 PM
Scottybclarky
Welcome to FTE
My truck is 2wd and the transmission i got with the truck is trashed, i ended up in a lawsuit with the guy who was repairing it so as of right now i do not have it. Do you know what vehicles have the same transmission mine does, i would like to put in the same trans that came with the truck. I have the bell housing so im just looking fir a tranny that will bolt right on
Old Jan 20, 2015 | 05:42 PM
NumberDummy
Ford type 3.03 3 speed manual all syncromesh transmission.
Direct fit: 1965/66 F100 240/300 I-6 2WD with same wheelbase as your truck has now (either 114" or 129").
Will fit, but modifying the drive shaft will be necessary: 1967/79 F100 240/300 I-6 2WD / 1975/79 F150 300 I-6 2WD
240 I-6 cancelled at the end of the 1974 model run.
Suggest you join FTE's TX Chapter, the more people you know, the easier it will be to find parts.
j saladbar
Dec 2, 2018 07:02 PM
Fellenz
16
Jun 1, 2015 10:17 PM
portagoosey
Jan 12, 2014 10:06 AM
juang316
Sep 20, 2013 11:30 AM
nineteen sixt5
Sep 14, 2013 10:28 AM
