292 Starter
Old Feb 4, 2015 | 12:39 PM
Rusty_S's Avatar
Rusty_S
I picked the starter up today just a few mins ago on my lunch break. Was $175 after tax for the starter. I figured it also included the labor for swaping the old bendix from my old starter to this starter.
Not bad though in my book for a brand new starter. Plus I have a piece of mind cause they tested the starter twice once before the bendix was installed and once afterwards to ensure proper operation.
Old Feb 4, 2015 | 01:26 PM
Tedster9's Avatar
Tedster9
Very good, Rusty!
Old Feb 4, 2015 | 04:26 PM
Tedster9's Avatar
Tedster9
Here are some pics of two rebuild candidates. One is seized up pretty good and the other was R&R'd just on general principles. Between these two, a replacement armature and rebuild kit should be able to make at least one good starter to keep on the shelf or take on long road trips.
Looks to me like the armature was dragging on the field coils and it got pretty toasty in there sometime. The commutator looks OK I guess, dunno for sure.
Old Feb 8, 2015 | 06:15 PM
Rusty_S's Avatar
Rusty_S
I went ahead and used some alcohol to remove the yellow paint stick markings they put on the new starter for the part number and I affixed the reproduction decal as best as I could since I could not find any information on placement or if it should be horizontal or verticle.
Hardest part was that starter to bellhousing seal. I didn't look at my shop manual so I didn't realize you have to hook the ring in the groove on the bell housing the press the cup rubber flap down into place. I was trying to place it on the starter itself and was wondering why I cant get but two of the three bolts to line up.
I got that squared away though which is a good thing. I also think its funny now that I am using a 6V starter but my decal says its a 12V starter. But boy does it spin the engine over fast though. Battery was discharged due to cold weather and sitting two weeks since I last charged it but after getting a good charge in it it worked good. Next step is the generator and I don't know if I want to just use my new pieces or just take it in and let the same guy rebuild this one but he might tell me I need a new one and it would be cheaper. I didn't mind the starter but I prefer to have the generator rebuild I don't see how it would cost more than a new generator vs rebuilding.
Old Feb 8, 2015 | 06:33 PM
Tedster9's Avatar
Tedster9
The seal doesn't just fit on the starter, and then everything bolts right up? Huh. Saved me some swear words I bet.
Old Feb 8, 2015 | 06:38 PM
Rusty_S's Avatar
Rusty_S
Nope. There is a groove in the bell housing you take the cupped side of the seal and have it facing the block place the ring in the groove and then slide the cupped side down till it is flush in place.
I tried it fitting it on the starter and for almost half an hour cursing wondering why I couldn't get the top bolt to start. After I took it out and inspected it found this out did this it only took about 5 minutes with a shallow 1/2" socket and a 6" extension to get it started.
Old Feb 8, 2015 | 06:49 PM
Tedster9's Avatar
Tedster9
Huh. I'll be dipped. I'm not sure a 64 even came with this seal, but thought it might help keep grime out or something. It isn't even hardly visible then is it?
Old Feb 8, 2015 | 07:07 PM
Rusty_S's Avatar
Rusty_S
Honestly all you really see once its installed is the rubber ears that wrap around the top and bottom eyes for the mounts and a little black rubber of the ring where the starter does not cover between the mounting points.
I am not sure but I believe all the Y-blocks came with this seal to keep water and dirt out of the bell housing. I cant say for sure but I think when I got mine Dennis Carpenters site listed up to 64 unless I am mistaken.
Tennesseepowerstroke
1983 - 2012 Ranger & B-Series
Apr 29, 2014 11:20 PM
JoeHarbourJets
Nov 7, 2011 09:12 PM
awils961
Virginia Chapter
Feb 11, 2011 05:15 AM
gordo350
Nov 19, 2004 06:22 PM
freddie
Jan 17, 2000 09:34 AM
