need help. 95 bronco axle issue
I keep breaking the front u joint on the rear drive shaft. I know it has to do with the pinion angle and the fact that it has a 3/4 ton yoke on the t-case. The drive shaft sits at a very odd angle. My question is there a way to fix this without doing a whole 3/4 ton rear end swap and drive shaft swap? 6 inch suspension lift stock axles. 460 c6 conversion I'm stumped
casanovaceo
09-03-2004 10:10 AM
