RADIATOR FAILURES 2008-2010 F250-350
About your radiator problem
The problem is look at that part that the radiator is hooked to got three bolts on one side three bolts on the other side the radiator core support asware Ford messed up at if they would have welded that part not use bolts everything been fine then you don't see no other trucks having this problem you don't think that's radiator course report moves of course it does it ain't welded you got boats holding it just ain't done boats going to keep it still all the way when you're twisting and turning hell or no
trevorrules
17
03-20-2021 08:25 PM
triumph1200
1947 and Older Ford Trucks
03-08-2017 08:47 PM
