6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
View Poll Results: Radiator replacement model year
2008
42
93.33%
2009
2.22%
2010
4.44%
Voters: 45. You may not vote on this poll
Radiator poll
Old Nov 12, 2012 | 06:41 PM
slowmans's Avatar
slowmans
Radiator poll
Starting a poll to see what years are having radiator problems. if you have lost a radiator or many radiators vote for your year truck.
Old Nov 12, 2012 | 08:00 PM
senix's Avatar
senix
subscribing..should be rather interesting.
Old Nov 12, 2012 | 08:13 PM
parkland's Avatar
parkland
I have noticed that guys that have radiator issues, keep having radiator issues.
That makes me thing that something else causes the failure, and it's not just as simple as being a crappy radiator.
Mine is 2008 with 100,000 + km's and no rad issues yet.
Old Nov 12, 2012 | 08:15 PM
slowmans's Avatar
slowmans
Im leaning towards the 08's.....didn't they redesign something from the job 3's on?
Old Nov 12, 2012 | 08:18 PM
senix's Avatar
senix
same here. I have my original as well. I did have to replace the upper hose down in Florida summer before last but never let the coolant get low on the way there. Was towing the 5er too. Just checked it at every fillup and kept it full.
So I would be curious if these failures were combined with the need for coolant as well and how much and how often.
Old Nov 12, 2012 | 08:27 PM
parkland's Avatar
parkland
I also had the upper hose replaced, it was leaking slowly on engine and disappearing.
One thing I know, is that the cooling systems on these are really finicky, to the point that it barely follows the rules of physics haha.
Some old diesel mechanic told me: 2 biggest causes of diesel engine retirement; catastrophic failure, and cooling system issues.
Old Nov 12, 2012 | 09:05 PM
RM2738's Avatar
RM2738
Replaced upper rad house. Caught the leak extremely early. Most likely the same day it started.
Old Nov 13, 2012 | 07:12 AM
Gearitis's Avatar
Gearitis
Knock on wood, No rad issues or rad hose issues with 87k on the speedo.
Old Nov 13, 2012 | 02:17 PM
pilotshot's Avatar
pilotshot
I have 63,000 miles/102,000 kms on a very early Job 1 2008. I have had no issues with rad or hoses. When I had a cab off repair last year for an oil leak, I upgraded the early thermostat as I believe some of the rad problems may come from the early thermostats. I will now replace the early rad cap to ensure the rad pressure stays at about 16PSI.
Old Nov 13, 2012 | 09:37 PM
StanleyZ's Avatar
StanleyZ
56,000 miles on an early 08, no radiator problems. I bought mine with 4000 miles on it but the original owner said he had the recall for the TSB on the hose done when truck had just a few hundred miles on it.
Old Nov 20, 2012 | 10:35 AM
slowmans's Avatar
slowmans
so 7-08's....there has got to be more replacements?
Old Nov 21, 2012 | 03:30 AM
aquaman's Avatar
aquaman
43K on my '10 with no issues
Can you modify the poll to include a 'no' for each year?
Old Nov 21, 2012 | 08:50 PM
mangymarmot's Avatar
mangymarmot
2008 Job 2 F450. Radiator replaced at 28k. Upper radiator hose replaced at 34k. Currently has 35k on it.
Old Nov 21, 2012 | 09:16 PM
slowmans's Avatar
slowmans
I dont know how to change it, but I like it the way it is. I think we are all only concerned with the outcome of ones that have been changed.....
Old Nov 22, 2012 | 02:15 PM
TIRE FRYER's Avatar
TIRE FRYER
08 job 3 truck. 56k miles. Second rad going on third
