i have a 69 f250 cs the po messed up the steering colum (took nut off and tried to take steering wheel off with a hammer), found a steering colum out of a 77 ford not sure what kind probably f150 it was complete except in pieces and the metal piece that makes the turn signal return i got it all together (what a pain in the obama) all i need now is turn signal switch and the return clip and the horn wire is there any place to buy them that isn't chineese most of the places i've checked say made in r.o.c i also need the insrument voltage reg mine died no fuel,no temp,no oil of course no dash lights but that is a seperate circut. any help would be most appreated.
Not sure what you mean by horn wire and return clip. Horn wire and it's brush is in the T/S switch. Also the cancelling mechanism.
73/77 with A/T,w/o cruise...D3TZ13341B.
75/77 with A/T and if you want to add cruise..D5TZ13341B.
DC shows the D3TZ one for $100.00 in my Feb 2013 catalog. Or let me know which one you'd be interested in. I'll run it on the locators.
C7TZ-13318-A
No Reviews Be the first to review this product
Turn Signal Turn Off Cam
<!-- <input type="hidden" name="formName" value="dmiformShoppingCartAdd" /> --> <input name="productNumber" type="hidden" value="C7TZ-13318-A"> <input name="parentProductNumber" type="hidden" value="C7TZ-13318-A"> <label class="control-label control-label">Status</label>In Stock
Maybe what the OP is referring as a return clip is the NSS selector lever. But regardless...by now this little charmers knife blade end has probably snapped off.
