Turn signal help?
Old Nov 23, 2014 | 07:26 PM
Nicktitan's Avatar
Nicktitan
Turn signal help?
have a shared project with my buddy - a 71 F100, and the turn signals are going wonky on us. The only one that works is right rear, but the emergency flashers and brake lights work like a million bucks. What could be the issue? I thought that all of that ran off the same circuit?
Old Nov 23, 2014 | 07:35 PM
D & D's Avatar
D & D
Flashers and turn signals are on separate switches. If the flashers work, wiring, housings and bulbs are good. Sounds like the turn signal switch in the column is bad.
Old Nov 24, 2014 | 09:49 AM
Rasputin53's Avatar
Rasputin53
1. Remove the negative battery terminal.
2. Remove the horn button.
3. Remove the horn contact spring from the steering wheel and put in a safe place (like the ash tray)
4. Remove the steering wheel.
5. Clean the contacts in the switch with some 1000 - 2000 grit sand paper.
6. Reinstall parts.
The only reason to replace the switch IMHO, is because the return cam is busted off or the wires are bad/hacked. Otherwise, it's simply a contact cleaning.
wyrm73
Oct 26, 2015 11:27 PM
PRUSue
Aug 24, 2013 08:52 AM
camcol19
Aug 22, 2013 04:17 PM
davewave649
13
Oct 6, 2012 12:50 AM
ragphoto
17
Feb 13, 2011 05:21 PM
