clutch equalizer part....what do i do?
Old Jan 14, 2015 | 11:34 AM
breezesboy's Avatar
breezesboy
So I removed my clutch linkage and I am now ordering new parts for it. I can get everything I need from lmc but I cant find the pivot parts for where the release rod attaches to the equalizer...anyone know where I can get one? I don't even know how it comes off
Old Jan 14, 2015 | 01:35 PM
TheRedPheonix's Avatar
TheRedPheonix
If that last washer is not split so it can be spread and slid off then it is essentially riveted on and will need to be ground off or left alone and reused. Your other option if you need if for the new linkage is to build a new one.
Old Jan 14, 2015 | 06:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
That looks non-removable, it should come as part of the equalizer shaft.
Old Jan 14, 2015 | 06:28 PM
HIO Silver's Avatar
HIO Silver
Cut. Fab. Weld. Welders are soooo useful.
Or replace it with a rod joint and a thru-bolt... more better as double-shear but that would require a welder... seewhattamean?
arnouxt
Dec 27, 2016 05:48 PM
Bluethunder3320
Nov 17, 2014 07:04 PM
SeaBeeCm1
Jun 9, 2011 07:31 AM
Auburn56
Oct 24, 2009 08:26 PM
Blue50F-1
Mar 23, 2009 10:35 AM
