Test Run on IDI
Old Jan 14, 2015 | 11:12 AM
mark460's Avatar
mark460
Test Run on IDI
Looking at a diesel 1990 F350 truck for sale, not running. Seller is telling me it needs a fuel pump. Is there any easy way to rig up a electric fuel pump to test run the engine to make sure it runs ok before I buy the truck?
Old Jan 14, 2015 | 12:07 PM
Ford F834's Avatar
Ford F834
If he means the lift pump then yes, it is just a mechanical pump bolted on the passenger side of the engine. You can take the rubber fuel line off and feed it with an cheap electric lift pump out of a can. You could also just bring a new lift pump, they cost about $27 at Autozone. But honestly if it was just the lift pump, the owner would have done it already and had a running truck to sell. If he means the injection pump that is a whole different story...
Old Jan 14, 2015 | 12:29 PM
The_Josh_Bear's Avatar
The_Josh_Bear
To be honest the engine should run without the pump working at all. There are a few stories of fuel pump failure and the IP pulled the fuel anyway. I'm one of them.(not saying it'll run great, but should run)
You don't even need the e pump you can just run a hose into a bucket on the fender and the IP will pull it's own fuel to run. Purging air is a different story, and much easier with the e pump.
If the fuel input hose is like mine, it's pretty easy. It's a metallic hose coming out of the filter inlet, but becomes a rubber hose after a few inches. So it's easy to just cut the hose and insert the e pump, or however you see it best to MacGyver it. Just depends on how many barbs and "T's" you want to use, and how much hose.
Old Jan 14, 2015 | 01:17 PM
mark460's Avatar
mark460
Seller said he's not a mechanic and doesn't know much about the truck, so he wouldn't know how to change the pump. His son changed out the fuel filter and tried starting, after cranking they checked the filter and didn't see any fuel so they think its the fuel pump. They also said they had the fuel sender off, so I'm thinking it is the lift pump or could be the selector valve. I wouldn't want to buy unless I can hear the thing run, so maybe I could bring along an electric pump and a fuel jug. I don't' want to mess with a bad injector pump though.
BTW, I did have a lift pump go out on an old Cummins, I could still drive it, but as soon as I cut it off it wouldn't' start again.
Old Jan 14, 2015 | 01:26 PM
bashby's Avatar
bashby
You could just get a 3/8 squeeze bulb and a can of fuel. I bought one at Walmart in the boat section. Hold the Schraeder valve open while pumping it until you get the air out, then loosen as many of the lines at the injectors as you can get to. (5/8" or 16 mm wrench) a half turn is all you need. crank the engine while pumping the bulb. Hold the accelerator to the floor. Crank 20-30 seconds then wait a couple minutes or you will burn up the starter. Good chance you will kill the batteries, so bring a charger and/or a good set of cables.
Old Jan 14, 2015 | 02:44 PM
Ford F834's Avatar
Ford F834
It can be very hard to purge the air out of a new filter. I actually had to have someone loosen the filter while I cranked the engine until fuel sprayed out of the filter seat. Then it would start. But the seller of this truck tried a new fuel filter for a reason, so the lift pump may be bad. I still say it sounds a bit fishy. The whole "I'm not a mechanic but I believe it's just xyz cheap part..." is a classic red flag. Just sayin' be careful. The lift pump is two bolts and a couple hose clamps to change out. Perhaps a 15 minute job and you don't have to be a "mechanic" to do it. Some people really are that ignorant about cars and you might land a deal on an easy fix but beware of the other possibility...
Old Jan 14, 2015 | 04:25 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
if he can't replace a lift pump to sell a running truck then that's his issue.offer him scrap value + the part value you see only for a vehicle that's not running.
Old Jan 14, 2015 | 08:47 PM
irhunter's Avatar
irhunter
+1
I think, about best case, is you'll get it to roll over and idle. It seems pretty iffy that you'll get it to the point of a highway test drive before buying it. Buy it for cheap, get it home, and give it a good work up.
Or, find another one that runs.
What is the asking price, as it sets?
Roy
Old Jan 14, 2015 | 09:00 PM
Ford_Six's Avatar
Ford_Six
As a policy, I never start a "it just needs this" truck at the seller's, even if I think it may be something cheap and quick. I have seen too many cheap trucks turn into free repairs for the seller, then the price either jump way up since it runs now, or no longer for sale.
If the price is good, buy it, then tinker with it. If it cranks over nice and smooth, then get it. Worst case is it's a bunch of parts.
As a side note, these filters need to be filled before installation, most non-diesel people don't know that and condemn other stuff because of their improper installation. It may need nothing.
Old Jan 15, 2015 | 08:44 AM
tjc transport's Avatar
tjc transport
i ain't rite
it also may not even need a lift pump, it may just be out of fuel because the pickup in the tank is broken.
Old Nov 4, 2019 | 05:21 PM
Stumblefoot's Avatar
Stumblefoot
The IDI is really super simple, Bypass the mech fuel pump and put an EFP on it. Bleed the filter, open a few injector lines at the injector, and it should start, One thing to check is glow plugs and glow plug relay. easy to check glow plugs. But even on a warm day the darn things won't start without the glow plug system working.
Old Nov 4, 2019 | 10:39 PM
FORDF250HDXLT
If he's still on the fence with buying this one after four years,Stumblefoot, he'll never have a chance at committing to a relationship with a girl.
Though in this day and age, that may be for the best just the same anyway.
freightdogfred
16
Jan 30, 2019 09:15 PM
Nick bass
Aug 12, 2012 09:30 AM
kenpobuck
May 16, 2008 07:44 PM
dennis11
Feb 17, 2008 10:25 PM
kawa
Dec 21, 2007 11:33 PM
