1988 f250 4x4 5 speed 7.5L 460. I bought this truck 3 weeks ago as a project. It runs and I drove it 160 miles home. The problem is that it was an EFI and he converted it to a Holly carb. I'm ok with the carb but not the way it is plumbed. The rear tank is plumbed with a single line to a after market inline pump mounted to the frame ( he cut the pump off the in tank sending unit) and a single line to the carb. I'm installing new in tank pumps and all new fuel lines to the resevoir/selector. I don't know how to plumb past the resevoir as I am not using the high pressure pump. What do I do with the return line on the engine side of the resevoir ? Most of the original fuel lines are missing so it's hard to figure out the routing. Any help will be appreciated. Thanks
As far as the fuel tank selector reservoir you do not need it. Just replace it with a fuel tank selector solenoid valve and run the lone wire to one of the tank fuel pumps.
