fuel p/u problems..still....
Old Oct 12, 2007 | 04:29 PM
camperspecial65's Avatar
camperspecial65
The nightmare continues....got new carb on and all...good carb I got from a fellow FTE er...thanks I fired it up yesterday...or tried to...started off fine with initial prime but it seems that its not picking up from the tank...my guess anyway....I went and took a looksee at a tank from a 66 Im gonna be getting for nada in a lil bit...question is...A..how far down does the tanks pickup go to? and B...whats the pourpose of there being a 2nd tube going down into the tank from the p/u line area...one runs straight down like I would expect but the 2nd one goes down a bit and about 1/2 way down goes to the side and follows it down to the bottom...I havent cut open one of these to see exactly what it is which is why Im wondering...
The other thing Im wondering...I have one of those floor mounted switch levers for the extra saddle tanks it once upon a time had...has anyone ever heard of these things going bad ????
Let me know...and thanks in advance guys
- cs65
Old Oct 12, 2007 | 04:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Suggestion.
Hipoparts.com sells a CD of the complete 1964/72 Ford Truck Parts Catalog. An excellent pic of the fuel lines can be found in Section 90; Page 4 of the Illustration Section. This illustration only shows one line leading from top of tank to carb. I doubt the mechanical valve on the floor is causing the problem. I'd look for a pinched or restricted fuel line.
I assume the fuel pump is OK, and the internal fuel pump fuel filter (as original) isn't clogged.
Old Oct 12, 2007 | 05:09 PM
camperspecial65
Ya...Im on the 3rd fuel pump, 2nd new one(1st had weak p/u pressure)...it bottle feeds fine last time I checked a month or so ago. everything from fuel pump to truck rubber line forward has been replaced.
I also doubt the mechanical valve on the floor is the problem. Im gonna try to find a decent strong flashlight and see if I can look into the tank and see what the p/u line looks like...Im down to either the tank p/u inside beings bad or the external lines along the frame being bad...but I have blown backwards from the fuel pump line rearward w/o problem....so Im thinking its the p/u line as Ive looked at the lines on the frame and no signs of leaking or weeping or smell of gas.
So Im off to get another tank...if mine is ok theres nothing wrong with having a spare ....plus a sending unit...btw...ND...you mentioned a few weeks back there were 2 types of gaskets used on them...wheres the split at...is up to 66 one type and 67 up being another or ????
Thanks for your help...Im gonna be getting that cd of the parts books...for 20 bucks, all but impossible to go wrong...
- cs65
Old Oct 12, 2007 | 05:31 PM
Redmanbob's Avatar
Redmanbob
If it's getting fuel on the carb end (bottle feeding fine) what makes you think the pump isnt working ? Any chance you have the line swapped at the pump? remove pump disconnect both lines and pump the arm pay attention to which whole the gas comes out.. that the carb side..
Old Oct 12, 2007 | 05:40 PM
NumberDummy
- cs65
Sending unit gasket is what you are refering to? There's only one for the incab tank = C1TF-9276-A. The sending unit is still available from Ford = D7TZ-9275-G; as is the float = C0AZ-9202-B. Suggest you buy from a FTE supplier, as they give a dsicount to FTE menbers. y2kfordparts (Millennium Ford in Seattle) is in your area.
NumberDummy
- cs65
Sending unit gasket is what you are refering to? There's only one for the in-cab tank = C1TF-9276-A. The sending unit is still available from Ford = D7TZ-9275-G; as is the float = C0AZ-9202-B (float and gasket supplied with sender, or available separate). Suggest you buy from a FTE supplier, as they give a discount to FTE members. y2kfordparts (Millennium Ford in Seattle) is in your area.
The parts catalog offered by Hipoparts is the one I use here on FTE.
Old Oct 12, 2007 | 07:25 PM
camperspecial65
ND...will dealers like Millenium give discounts to FTE members on any part...so long its truck related or does that apply to car stuff too ???
As to what redmanbob mentioned above...I have replaced 2 new fuel pumps...when I mean bottle feeding, I mean disconnecting the tank and frame rail lines from the scenario...i.e., undoing the rubber line from the truck fuel line @ frame rail and bottle feeding thru the pump upwards...the 1st pump I swapped out....it wouldnt bottle feed at all...
I appreciate all the input...keep it coming :-)
- cs65
Old Oct 12, 2007 | 07:27 PM
camperspecial65
btw...with it all together like it should be...no gas at carb...
Old Oct 12, 2007 | 09:13 PM
ol yeller's Avatar
ol yeller
You probably picked up some trash from your tank. These old things are good at it. discount ford or obsolete ford or whatever they are in ok city sells all of it. but like number dummy said some of the fte sponsors give a discount.
Old Oct 12, 2007 | 09:20 PM
Redmanbob's Avatar
Redmanbob
Try disconnecting it at the pump to tank hose and blow in the line to see if it sends air into the tank(freely) if not try a "little" compressed air and see if that might free it up.. if there are any air leaks in the line between pump/tank that would halt the pumps function also..
Old Oct 12, 2007 | 10:48 PM
rogue40's Avatar
rogue40
From reading this I'm convinced that the fuel pickup tube has either cracked, broke or rotted off.
Pull out the sending unit and look inside the tank with a small inspection mirror and flashlight. You should be able to see if that is the problem.
Stupid question time: Is the fuel tank selector switch in the right position? Sorry, I had to ask. Anyway, I would remove the switch and hook the fuel line up directly to eliminate it as a possible problem down the road.
Old Oct 13, 2007 | 04:12 PM
camperspecial65
well, I have gotten a spare tank...free is a great price...and my mechanic also mentioned popping the sending unit out and having a looksee..do the gaskets usually die when they are popped out or not ?? Im just wondering if I should get another one is all...
When I did the fuel pump a cpl months or so ago, I was able to blow backwards in the line w/o any problem...the aux. tank mechanical switch is in the right place.
- cs65
I got a temp issue with my Ranger if any of ya wanna chime in over on that group...
Old Oct 13, 2007 | 04:20 PM
NumberDummy
- cs65
The gasket (C1TF-9276-A) is cork as original, and once used, should be replaced. Cork tends to shrivel with age, and then needs to be soaked in hot water to bring it back to its original shape.
Old Oct 14, 2007 | 09:52 PM
64fordf100292's Avatar
64fordf100292
just out of curiosity, what ya gonna do with your old sending unit? does it work?would ya consider selling it for a few bucks?????? mine is bad and I am gonna eventually do a tank conversion, so i dont wanna buy a new one. ya know, thinking ahead.
Old Oct 21, 2007 | 12:58 AM
camperspecial65
Ya, I have spare sending units I can part with...drop me an email direct with mailing info and all...
Bill, I got me a sending unit gasket for my beast...I was of the impression it would be a wider ring with holes in it to line up with bolts on tank...the one I got is a cork one...about 1/4" wide by about 1/8 thick...I havent replacedone of these nor seen how the tank is set up to recived the gasket...is there a recessed lip in the opening that the ring sits in ?? or is it a flat area you eyeball before you suck the bolts down ???
Let me know as Im gonna be giving it a looksee in the next few days...
Thanks, cs65
