Sponsored by: Real Truck
OEM Subwoofer install
Old Jan 10, 2015 | 09:42 PM
-JD-'s Avatar
-JD-
Just picked up an OEM subwoofer from the ford dealer and trying to figure out where it is supposed to be installed.
Does it go flat below the rear seats or upright behind them?
Where would I find the pigtail connector that connects to the sub/amp box?
Or even more importantly, can this unit atually be added to the truck after the fact?
Old Jan 10, 2015 | 09:46 PM
my_crib_too's Avatar
my_crib_too
Welcome to FTE...
Old Jan 10, 2015 | 11:09 PM
superdutyquest's Avatar
superdutyquest
It mounts behind the rear seat against the rear wall if you have a crew cab.I hope you didnt have to pay for it.If you did,get ready to be disappointed.
Old Jan 11, 2015 | 01:27 PM
-JD-'s Avatar
-JD-
Passenger's side or drivers side?
I see a bottle Jack behind the passenger's side rear seat...
Old Jan 11, 2015 | 01:41 PM
cabindoc's Avatar
cabindoc
Passenger side if it is a crew. My jack is on the drivers side. Should fit like a glove if it is the correct one. Plug s/b in the vicinity if it is lariat. If not, you may have to run wires yourself.
Old Jan 11, 2015 | 02:22 PM
-JD-'s Avatar
-JD-
That may be the problem. It's not a lariat and, obviously, didn't come with a subwoofer from the factory. Is it unlikely to have the wiring for one then?
My dealer gave me the impression the wiring should be there and it should be 'plug and play'.
Old Jan 12, 2015 | 06:24 AM
Just Strokin's Avatar
Just Strokin
There is a good possibility the wire will be there. You didn't say what or style cab you have, but looking at the 2015 wiring diagram, it appears it might be in the wiring harness for the seat belt, door speakers that runs to the rear...check under the mats and you
might find it....it sure didn't appear to be a separate wiring harness.
Old Jan 12, 2015 | 06:24 PM
-JD-'s Avatar
-JD-
Sorry its a 2015 XLT crew cab.
I'll try to have a look later today to see if I can see it around the seatbelt wiring.
Old Jan 13, 2015 | 08:31 AM
RightWingNutJob's Avatar
RightWingNutJob
I don't think that it's "plug & play" for our truck. The XLT wiring diagram just shows the wires for four "standard" speakers. The subwoofer and its amplifier are included with the "Premium Audio" at the Larait & above trim levels.
I think that in addition to the subwoofer, you're going to have to get a line level converter to tap into the audio ouputs, an amplifier, and some sort of a crossover network to power that sub-woofer speaker.
Old Feb 28, 2015 | 11:23 PM
txazguy's Avatar
txazguy
What's the part # you ordered??
RippedF350
Dec 10, 2011 12:56 AM
Chriscubano
Jul 21, 2011 05:17 AM
NDNMOJOMAN
Oct 1, 2006 09:19 AM
SDS
2004 - 2008 F150
Nov 4, 2003 03:27 PM
93bigbronco
1978 - 1996 Big Bronco
Mar 11, 2002 11:30 PM
